Home -> Forums -> Construction -> Layout and House Plans -> West house plan for 1800 sq ft
Thu Jan 17, 2013Total posts : 1
sainadh
sainadh
Topic: West house plan for 1800 sq ft
Dear experts,
Please provide me a layout and house plan and cost estimation for the West facing house as per vastu.(Featured floor plan: 2 floors):
1. Total land area with west facing = width: 33 ft,  length = 56 ft.
                                = 1800 Sq.ft
2. Ground floor Build up area = 1300 sq.ft;
                         1st. portion   = Hall -1,Bedroom-1,Kitchen - 1, Toilet- 1
 2 nd portion  = Hall-1, bedroom-1, Kitchen-1, toilet-1
2. 1st floor build up area = 1300 sq.ft
                         Floor plan = 3 BHK  with storage room and pooja room.
Please send me the floor plan for above with cost estimation. Pl. help me rugent to my below mail ID.
yours truly
Sainadh.ch
e-mail: sainadh.67@gmail.com
Fri Jan 18, 2013Post  #1
Post subject: ready made plans on gharexpert.com
We have service for the construction cost estimate which would give you the brick by brick cost calculation.
Our detailed cost estimate pricing is based on the built up area of the house and price slabs given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.25 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.75 per sq.ft.
Above 10000 sq.ft area= Rs.1.25 per sq. ft.
We will take almost 10 business days to prepare the detailed cost estimate.
For preparing the detailed cost estimate, We need the following documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Please supply floor plans.
7. Also supply Exterior elevation and structural drawings if possible.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
1366
Hi, I would like to construct East-facing house in 50 * 72 sq ft (50 length & 72
Last answer on 5/17/2016 12:06:23 PM. by Beenu Phogat. Forum started by Shalini
2242
i want a house plan 33*33 sq. ft west facing. pls help me thnak you
Last answer on 8/8/2017 12:04:30 PM. by Saurav anand. Forum started by yogesh
2005
if any have photos of best house plans with 900 sq.ft plse send it
Last answer on 7/27/2016 2:33:34 PM. by Beenu Phogat. Forum started by ram
3373
forward me some house plans(1200-1500 sq ft)
Last answer on 5/14/2011 9:57:26 AM. by mani. Forum started by BINU SAMUEL
3129
3083
4371
Last answer on 4/25/2014 2:55:51 PM. by seema tyagi. Forum started by PANKAJ
3324
can u plz send me a house plan for 32*38 ft west facing plot
Last answer on 7/4/2020 1:59:49 AM. by HOME. Forum started by sujitha
14312
20 sq ft and 50 sq ft how can i make house with vastu
Last answer on 12/24/2012 3:50:59 PM. by S L Gupta (Civil Engg). Forum started by saravanan
1982
north to south face 4 bedroom plans 1800 sheet 48 chorai 35 lainth map images
Last answer on 2/25/2015 9:23:56 AM. by seema tyagi. Forum started by neelam
3635
3414
I am in need of lay out plan foo house.land area 600 sq mtrs.60 ft x 90 ft.
Last answer on 8/3/2012 2:05:24 PM. by Ar. Manoj Ralen. Forum started by viqar idris
1541
I want to construction of a double stored building low cost total 1800 sq ft no
Last answer on 7/13/2020 3:16:36 AM. by Beenu Phogat. Forum started by Samaresh Mohanty
3899
3433
2431
Electic wires
Last answer on 1/17/2014 12:15:51 PM. by S L Gupta (Civil Engg). Forum started by rajesh
1998
Regarding Construction Cost
Last answer on 10/20/2015 11:33:37 AM. by S L Gupta (Civil Engg). Forum started by Sagar Hande
5353
main door vastu question
Last answer on 7/4/2020 3:03:42 AM. by geetika. Forum started by sujatha
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2241
3595
2324
2090
2792
1548
2114
What is acre
