When we bought TMT bars for house, they said it was anti-rust. We had to stop ou
Fri Aug 10, 2018Total posts : 2
Vineeth V
Vineeth V
Topic: When we bought TMT bars for house, they said it was anti-rust. We had to stop ou
When we bought TMT bars for house, they said it was anti-rust. We had to stop our construction for last 5 months due to some difficulties. Now there is rust on its surface. Is it safe to use it. Or should i contact them. Is it normal for TMT's to have rust on them. I am planning to resume construction soon. It is grade Fe 415
Thu Aug 16, 2018Post  #1
       After long time TMT steel bars having rusting color due to store it in open due to moisture, it is cleaned up to some extent during bending binding by steel binder as they use gunny bag pieces in their hand for handling the bars during bending binding. If you doubt in mind than hire balder give them gunny bag pieces and kerosene oil for cleaning the bars.
Sun Aug 19, 2018Post  #2
      Thank you.
1622
1589
1502
3753
2613
1272
3039
use of tmt bar
4070
steel requirement
3230
2627
Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Last answer on 9/30/2016 2:16:48 PM. Forum started by vinu
2474
1740
2305
3179
Last answer on 3/14/2021 11:13:22 AM. by S L Gupta (Civil Engg). Forum started by venkatesan.pt.
2629
regarding facing of site / house
Last answer on 9/30/2021 5:39:44 AM. by Alexander Graf. Forum started by nandu
2702
i am planning to buy a house. Which direction should the main door face?
Last answer on 11/10/2011 9:59:03 PM. by shekar. Forum started by vandana tak
4159
Is this Gaumukh plot
Last answer on 11/27/2021 5:39:50 AM. by Ar. Manoj Ralen. Forum started by kpatel
3672
foundation depth and cost in black cotton soil (REGAD)
Last answer on 4/6/2021 5:18:58 AM. by S L Gupta (Civil Engg). Forum started by shaik
TMT
Buying
Buying Guide for Garage Door
Buying tips for Bricks
Buying tips for Brick Blast
Buying
Buying tips for Cement
HSD
Type
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
