Home -> Forums -> Construction -> Start Construction -> Where should i enquire good quality building material?
Fri May 31, 2013Total posts : 1
ananth
ananth
Topic: Where should i enquire good quality building material?
Dear All,
Where should i contact for good quality material with reasonable price?
(Material Manufacuturer/supplier/hardware shop)
what is the different between Material manufacturer,material supplier and hardware shop?
Please advice.
Thanks,
Ananth
Sat Jun 01, 2013Post  #1
Dear Ananth
          First of all contact 3-4 building materials supplier and take the rates of different materials.
Then try the rates with material manufactures and purchase where low rates quoted but make sure that there should be no quality compromise.
2041
estimation
Last answer on 4/30/2013 12:39:09 PM. by S L Gupta (Civil Engg). Forum started by dan
2720
2945
Last answer on 6/25/2009 5:16:44 PM. by rose. Forum started by dinesh
2569
2312
its good.i would want to knw about the materials used for cabints
Last answer on 7/29/2010 2:44:52 PM. by vimal. Forum started by shreya
3437
Any interior decorators in Hyderabad quoting economical rates for quality service?
Last answer on 8/13/2015 11:52:23 PM. by JAI PRAKASH. Forum started by Murali
2105
led interior panels lights
Last answer on 12/23/2013 4:24:09 AM. Forum started by kamal
2350
2216
Tiles or Marble for Flooring
2281
which marble and its sub category to buy
Last answer on 7/3/2020 11:36:27 PM. by JAI PRAKASH. Forum started by sushantsah
1914
building material
Last answer on 3/23/2015 10:00:27 PM. by JAI PRAKASH. Forum started by shaheryar
2090
Modular Kitchen
Last answer on 7/3/2020 11:55:40 PM. by JAI PRAKASH. Forum started by paresh
7232
2 lakh litre water tank
1885
can i get the plans and material list would like to build this
Last answer on 6/18/2012 3:25:01 AM. by Gunjan Utraja. Forum started by Jeremy
3304
GFRC Construction
2554
Mortar Plastering
Last answer on 10/11/2011 6:37:02 AM. by S L Gupta (Civil Engg). Forum started by sunny420
2241
for wood work in kitchen please give some ideas about design & good material wit
Last answer on 6/4/2021 12:34:00 AM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
1954
ITS GOOD AND I WOULD LIKE TO KNOW ABOUT THE MATERIAL AND ITS COST PER SQUAREFEET
Last answer on 12/20/2010 5:06:42 PM. by ranjeetsaini. Forum started by CORDIALINTERIORS
1652
3312
2236
2312
2061
Fire
Specification of Brick
Comparison
Orientation
Orientation of Building
Cement
Cement Concrete
