Home -> Forums -> Construction -> Raw Material -> White stains in the walls and cracks in the walls
Wed Feb 23, 2011Total posts : 2
Muralidhar
Muralidhar
Topic: White stains in the walls and cracks in the walls
I am constructing a house, as of now I have two problems to be solved.
1. white stains in the walls - where more water sprayed for curing purpose.
2. Cracks are developing , where walls touch ceilings. We have not used lime for smooth finish.
Pl reply
S M bhat
Sat Feb 26, 2011Post  #1
Dear murlidhar
  1. In the newly constructed wall there are two main reasons for white stains, one is presence of salt in the bricks and other is due to salty water used in the masonry work. After curing work completed then let the wall to dry .When wall fully dried than all the salt in the form of white stain comes out than rub it with brush or with hard broom and clean it fully. Wash the wall with water (but it should not be salty water).
2. This crack is due to not providing proper slip to the RCC slab on the wall by not providing bearing plaster on the wall before laying the slab. For repair
The plaster should be removed from cracked portion. The joints should be widened at least 20 mm to 25 mm in thickness. Clean old material by washing and brushing.
Apply slight cut on edges in straight line to provide neat joint. Make the surface damp 24 hours before application of new plaster.
Cement mortar should be applied on defective portion. Make 20 mm wide and 25 mm thick groove at the junction of the slab and wall.
Keep the surface wet at least for 3 days. When surface is dry, finish it according to adjacent area on wall.  For more detail visit gharexpert construction section safety where crack articles give more information about repair.   Link is given below.
http://www.gharexpert.com/articles/Cracks-1468/How-To-Repair-Cracks_0.aspx
Sat Feb 26, 2011Post  #2
Muralidhar
Muralidhar
Thank you very much sir, for the useful reply.
2731
2712
2339
4109
4138
2898
2997
2336
3624
Wall unit
3381
Recurring Cracks
2676
Last answer on 1/10/2022 11:40:17 PM. by seema tyagi. Forum started by vaishali
1693
2581
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell
2925
1790
What are these stains on the new wall
Last answer on 4/9/2014 10:51:14 PM. by Purvi Panchal. Forum started by vamsi
1846
removal of the white mold from wall
Last answer on 4/22/2014 2:14:24 PM. by S L Gupta (Civil Engg). Forum started by piyush
2024
How much White Cement will be required as Primer Coat on Fresh Raw Wall for appr
Last answer on 6/24/2013 3:01:38 PM. by S L Gupta (Civil Engg). Forum started by JAYANT VERMA
2519
2929
Plaster
3076
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11105
2189
2038
Estimate
11123
3074
Steel
3039
use of tmt bar
1643
work turned out by labour
2457
estimate
1762
2993
3606
1943
Cost of Steel construction
1613
2136
READY MIX PLASTER
1866
2223
zero slump concrete
Canvas
Canvas Wall Art
How To Repair Cracks
Wall
Wall Decor
Decorate
Post
Post Painting Works
