Home -> Forums -> Interior -> Bedroom Ceiling -> Why suspended Ceiling falls down
Wed Oct 03, 2012Total posts : 2
Topic: Why suspended Ceiling falls down
Dear Sir / madem
I am going to construct suspended ceiling ( gypsum board ) in a residence. But I heard in some cases that it falls down. It may cause accidents.
Please suggest how to make it more safe, so that it can not fall down.
Thu Oct 04, 2012Post  #1
kamal
kamal
Post subject: below are some general reason
Usually a nail pop is caused by the nail being loose and not holding the drywall tight.
Fastener spacing, moisture content in materials should be contributing factors.
Nails or screws?
Spacing between fasteners in field and seams?
Visible corrosion on screw heads? If yes what % and areas involved.
Recent work or traffic in attic?
Visible signs of demise prior to failure? Seams bucking / cracking etc
Wed Oct 10, 2012Post  #2
Dear Purvi
           In construction work what ever the item , it is necessary tbout false ceiluo check the evry item to avoid defective work, keeping in view gharexpert provides many instruction if those are followed than there is minimum dificulty one can face.
As you want a suspended false ceiling problem.
1. The nail is not to be used, use steel screws which have capability to make treading where they are fixed.
Check 1st the vertical member fixed on the surface of ceiling by drilling and fixing it with rawl plug and  steel secrews.
Simillarly check the horizotal member either they are fixed with vertical members corectly with steel secrews.
Similarly check the gypsum board tiles fixing.
Care should be taken that all other work such as electrical etc to be done in advance not to distrub the false ceiling.
Bedroom Ceiling-Interior Questions (39)
1939
For doing false ceiling which direction we should bring down/up in desing
Last answer on 2/22/2021 2:30:00 AM. by S L Gupta (Civil Engg). Forum started by PALLAVI
3127
Dining Room Ceiling
Last answer on 7/2/2020 8:51:19 PM. by O'SirTee. Forum started by atiq khan
2965
i want desings of fall ceiling in apartment flat
Last answer on 3/12/2021 10:49:40 PM. by G N Shaikh. Forum started by shrenik
2583
Yes,I need some recently updated contemporary,suspended false ceiling designs.Pl
Last answer on 1/2/2021 5:27:40 AM. by S L Gupta (Civil Engg). Forum started by geetanjali
2294
slab
Last answer on 12/20/2021 5:13:48 AM. by ringwang. Forum started by ringwang
2265
i need some fall ceiling pic suport to my business and also wall decoration with
Last answer on 1/17/2022 2:10:25 AM. Forum started by Anoop Srivastava
2171
KINDLY TELL ME ABOUT DIMENTION OF FALL CEILING IN GYPSUM BORAD.
Last answer on 6/30/2012 11:31:21 AM. by Ar. Manoj Ralen. Forum started by Pawan Jain
3067
False Ceiling--POP or Gypsum, which is better?
Last answer on 4/28/2015 8:41:23 PM. by JAI PRAKASH. Forum started by ajaywahi
2190
Last answer on 5/5/2014 12:08:29 PM. by S L Gupta (Civil Engg). Forum started by ajaywahi
2260
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
2469
Suspended Stone Stairs
Last answer on 1/19/2015 2:55:07 PM. by awdhesh. Forum started by awdhesh
1609
can v down the floor in hall hall size 20* 20 down area 10*15down depth 1 feet h
Last answer on 1/2/2021 5:22:31 AM. by S L Gupta (Civil Engg). Forum started by durai
1656
Damaged Terrace Slab
Last answer on 6/7/2014 3:05:43 PM. by S L Gupta (Civil Engg). Forum started by chandran nedungadi
6714
Need a design for My ceiling
Last answer on 2/24/2022 2:27:55 AM. by taroset. Forum started by amar
1935
too bright & vibrant - should be toned down.
Last answer on 12/21/2010 6:44:53 PM. by Gunjan Utraja. Forum started by Vanshri
2188
down POP designs
2149
WHY CANT YOU ARRANGE AND SEND AN PHOTO
Last answer on 1/6/2013 11:43:38 PM. by vaseem. Forum started by shahin
2370
why you need a vastu an architect?tell me
Last answer on 7/4/2020 2:00:13 AM. by Gunjan Utraja. Forum started by GURDEVPAUL
3088
flooring
Last answer on 12/16/2015 3:40:28 PM. by JAI PRAKASH. Forum started by arun
2589
how to bring like this shape
Last answer on 2/24/2022 5:31:39 AM. Forum started by srinivaspatkuri
6714
3852
suggest me a house plan for 33 feet lenght and 19 feet width.plz suggest me home
Last answer on 2/24/2022 2:24:14 AM. by litaka4438. Forum started by sanjay
3215
COULD YOU WORK IN NIGERIA? I HAVE A JOB FOR .THE DESIGNS ARE OK
Last answer on 2/24/2022 2:16:07 AM. Forum started by Egbuta K C
3657
Hi,i need more details about this ceiling which is painted,may i know the refere
Last answer on 2/19/2022 3:13:16 AM. Forum started by okishore
3554
my mail address is okishore7@gmail.com Hi,i need more details about this ceilin
Last answer on 2/19/2022 2:43:17 AM. Forum started by okishore
2735
plz send me pic two wall texture and other paints and i want texture on celing
Last answer on 2/14/2022 11:13:57 AM. Forum started by nauman
The pictures are fabulous
Last answer on 2/14/2022 9:47:41 AM. Forum started by jennifer
2481
Hi i need more details about this ceiling which is painted,may i know the refere
Last answer on 2/10/2022 7:44:56 AM. Forum started by Lohit
1732
can u plz give me plan for cunstruction on my plot size 21*41 east facing 21 fee
Last answer on 2/7/2022 11:20:01 PM. by S L Gupta (Civil Engg). Forum started by sachin bidri
3746
sir I have built a residential house , I want plain ceiling roof casting for 12o
Last answer on 2/4/2022 4:13:31 AM. by Bentaev. Forum started by Kailash Sahoo
3704
hi, my hall size is 25 ienght and 12 wide .plz help for simple celling pop decor
Last answer on 2/4/2022 3:31:53 AM. by Gunjan Utraja. Forum started by ashok
4014
very nice pictures
Last answer on 2/3/2022 9:25:59 PM. by Gunjan Utraja. Forum started by sasikumar
1529
DEAR SIR, IS IT OK TO CONSTRUCT A SUMP IN N-E AND ON THE TOP THE HOUSE OR IS IT
Last answer on 1/27/2022 8:28:42 PM. by S L Gupta (Civil Engg). Forum started by SREEDHARGVN
3521
Nice design
Last answer on 1/23/2022 3:35:59 AM. by TanyaHerrera. Forum started by Imtiyaz
2331
hai this is ganesh. iam a small new builder. ur site is very helpful to me
Last answer on 1/22/2022 2:11:11 AM. by S L Gupta (Civil Engg). Forum started by ganeshkrg
3541
I am interested to build together with you.
Last answer on 1/21/2022 4:04:29 AM. by TanyaHerrera. Forum started by Egbuta K C
5950
gypsum
Last answer on 1/14/2022 2:23:44 AM. by Antoni11. Forum started by shaju
3268
nice ceiling drawing
Last answer on 1/13/2022 12:01:18 PM. by Karan Kundra. Forum started by deepak
2702
can any one tell me abt bamboo flooring .their cost and durability
Last answer on 1/6/2022 2:56:27 AM. by Swati Satija. Forum started by padmaraju
Ceiling
Basement Ceiling
Dining
Dining Room Ceiling
Kids
Kids room ceiling designs
How to clean plaster ceiling?
Living Room Ceiling
Ceiling
Ceiling Lighting
Why
Ceiling
Ceiling Fans
