Home -> Forums -> Construction -> Cracks -> Why are there hairline cracks in reinforced concrete beam and brickworks in my new 3 story building?
Fri Oct 03, 2014Total posts : 1
azeez
azeez
Topic: Why are there hairline cracks in reinforced concrete beam and brickworks in my new 3 story building?
In our new three story building,  there are one 15-feet width beam in ground floor and two 15-feet width beams in first floor, Other beams width are smaller than 12 feet.
I found a hairline crack in all 15 feet width beams. This beam size is 9 inch x 12 inch
I checked the reinforcement steal size in the design, it has two 16mm bar in the top, two 12mm bar in the middle, and (two 16mm + one 12mm) bars in the bottom
Also, I found there were many hairline cracks on the brickwork and in the joint of brickwork and column
What is the reason for this crack? How can I fix it? Could you please help me
I have attached  important plan pages and a sample crack
Attachments: Plan.pdf on Fri Oct 03, 2014,
north side.jpg on Fri Oct 03, 2014,
bottom.jpg on Fri Oct 03, 2014,&n
Fri Oct 03, 2014Post  #1
Post subject: cracks in concrete
Dear, one of the reason is that the beam has big span and may be overloaded, secondly cover to steel of beam is not properly given.
IF beam is showing the signs of bending provide suppoert of steel column at the center of beam.
If cracks are small break the the old cracked concrete step by step and fill the damaged concrte by using new conctre with epoxy chemical of Dr. Fixit
thanks
Cracks-Construction Questions (30)
3502
3624
Wall unit
2948
Lightweight Concrete Roofing
Last answer on 10/31/2012 12:32:07 PM. by S L Gupta (Civil Engg). Forum started by Ted Junior
3457
2502
2536
Civil Eng Stair Design
2536
2351
9885
3133
3941
3272
Roof Concrete Strength
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
1846
3842
10048
3304
GFRC Construction
1661
please send me south facing elevation of two storied building
Last answer on 5/19/2016 12:34:23 PM. by S L Gupta (Civil Engg). Forum started by jakeer
8421
Roof Beam crack
3381
Recurring Cracks
4137
5734
1591
How to renovate the broken staircase. please look the attachments.
Last answer on 4/25/2016 1:08:43 PM. by S L Gupta (Civil Engg). Forum started by chitta naik
1525
Cost for Polyurethene Grouting for Leakage from Flat Above
Last answer on 3/28/2015 6:24:30 PM. by JAI PRAKASH. Forum started by Unmesh
2278
2295
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by S L Gupta (Civil Engg). Forum started by Gagandeep
2058
Cracks in my new house
3133
4035
2648
How To Repair Cracks
Last answer on 5/6/2010 12:31:22 AM. by . Forum started by suni dutt panwar
Centering
TMT
Happy
Happy New Year 2009
Surface
