Home -> Forums -> Construction -> Foundation -> Will this roof fail?
Thu Sep 06, 2012Total posts : 2
Ravi Narine
Ravi Narine
Topic: Will this roof fail?
I have to build a room that is 15' wide and 8' high from floor to ceiling. It is an L shaped concrete building with the outside wall length of 35' on both sides. I need to build it with a slab roof about 4-5" thick perhaps. Is it possible to place just columns on the corners only and not within perceivable space to support the slab roof and what would the column dimensions be ?
[IMG]http://i1151.photobucket.com/albums/o635/nnigma1der/b5c4fe44.jpg[/IMG]
Thu Sep 06, 2012Post  #1
Dear Ravi
           You should send plan of the proposed building. without sitution one cannot be able to give any proper solution of the problem.You can take local help from any engineer or Architect.
Fri Sep 07, 2012Post  #2
Ravi Narine
Ravi Narine
the plan is at the link above
8420
Roof Beam crack
2850
2371
Roof construction
2158
1837
1791
12252
3980
Roof leakage
1647
2054
4647
1875
2352
laying of roof
3272
Roof Concrete Strength
2192
PLEASE SEND ME NEW DESIGN FOR HOME WALL & ROOF 10X12 ROOM
Last answer on 10/18/2013 4:07:28 PM. by S L Gupta (Civil Engg). Forum started by PRAKASH KUMAR
2090
2414
roof concrete
2413
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2203
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
