Window position on wall
Tue Aug 12, 2014Total posts : 3
Bhuwan
Bhuwan
Topic: Window position on wall
Hi Expert,
I am building a home through local contractor in my village, having 16 *18 ft room size, Can you help me figure out at what position I should fit the window on wall and what would be the best window size, roof height is 11 ft. I saw some people fit the window on 2.5 fit from bottom, I am planning to use 4*4 fit window.
another question, when we need to install the window frame, during wall construction or later on?
Thanks in advance.
Wed Aug 13, 2014Post  #1
Ahmed
Ahmed
Hi Bhuwan
The correct poistion in your case can be anywhere 3.5/4 ft since your roof is 11ft, generally on 10ft roof the windows is placed on 3/3.5 ft.
The std size of the windows is 4'.6"x 4'.6". Please do take care too much big windows also increase moisture and humdidy in your room .
Thu Aug 14, 2014Post  #2
Dear Bhuwan
           The height of window is different in house such as the height of window in drawing room may be 18'' to 24'' as the air come in the room to benefit the person on the sofa or chair, In bed room it may 24// to 27'' in kitchen it may at 36'' and in toilet it may be at 51'' to 54''.
  • Provide maximum ventilation in the East of the building if it might be possible.
  • Keep the minimum area of openings for proper ventilation and lighting excluding door opening more than 10% of the floor area of room.
  • Keep the minimum height of residential building not less than 3 meters.
  • Screen all the openings to prevent insect penetration and provide louvered protection against the entrance of rain and snow.
  • Install Exhaust fan in the kitchen or toilets for proper circulation of the fresh air.
    Thu Aug 14, 2014Post  #3
    Bhuwan
    Bhuwan
    Thanks Gupta Gi and Ahmed for your valuable suggestion.
    plz tell me ideal position of dental chair n patient position in east facing den
    Last answer on 7/3/2020 11:54:24 PM. Forum started by dr mona
    2194
    What is the best colour for the inside walls if I want to retain the colour of t
    Last answer on 10/26/2010 3:45:23 PM. by nevile. Forum started by Evas T. Bwoye
    1970
    hello my aquarium in my apartment was first in the west side and on the right wa
    Last answer on 12/31/2020 2:16:31 AM. by Priti Arora. Forum started by jasmine
    2535
    Position of Kalpavirkha to be planted in east facing house & boring position of
    Last answer on 7/3/2020 10:44:47 PM. Forum started by RAJ KUMAR KALIA
    1852
    2316
    I have to design my bedroom , its length is 16/12 and i have roung bed in that n
    Last answer on 4/18/2011 9:52:28 AM. by alagu chendur murugan. Forum started by shraddha
    2186
    1774
    position of partition wall
    Last answer on 3/5/2016 10:05:04 PM. by JAI PRAKASH. Forum started by ani
    2262
    About house positioned as diamond with directions (walls on NE, SE, SW, NW)
    Last answer on 4/5/2012 1:03:59 AM. by Amit Hasija. Forum started by Niraj
    2961
    Last answer on 8/1/2012 9:53:21 AM. by Ravi. Forum started by J J Gupta
    3512
    Last answer on 11/8/2021 10:59:52 AM. by nehamehta. Forum started by J J Gupta
    3516
    i need to know about the lift position and can the lift come inside the house
    Last answer on 12/31/2020 2:31:44 AM. by Karan. Forum started by vkausalya
    2873
    Position of staircase as per vastu
    Last answer on 2/3/2011 10:41:29 AM. by nith_piyush. Forum started by Bhovotosh Deb
    1821
    bed room in what position...???
    Last answer on 7/16/2015 9:59:29 PM. by JAI PRAKASH. Forum started by digvijay patil
    5342
    my toilt position east west,right or wrong as per vastu
    Last answer on 11/20/2019 11:37:25 PM. by JAI PRAKASH. Forum started by sukhamay
    3037
    Last answer on 4/1/2013 3:23:48 PM. by akmurty1. Forum started by kjeevanrao
    2104
    what is the correct sitting position for the reception in office
    Last answer on 8/9/2013 11:17:44 AM. by S L Gupta (Civil Engg). Forum started by yogesh laxman nalawade
    1856
    Last answer on 8/9/2013 11:20:50 AM. by S L Gupta (Civil Engg). Forum started by yogesh laxman nalawade
    1778
    thulasithara position at central courtyard
    Last answer on 2/22/2017 11:26:11 AM. by S L Gupta (Civil Engg). Forum started by ramesan
    AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
    Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
    Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
    Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
    Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
    Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
    Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
    Canvas
    Canvas Wall Art
    Wall
    Wall Decor
    Paint
    Comparing uPVC Windows with Wooden Windows and Aluminium Windows
    Window
    Window Treatments: Window Blinds for Windows
    Know about the different styles of window blinds and add style with window treatments such as blinds, shades, curtains..
    Wall
    Wall Accents for Your Rooms
