Window Size
Wed Feb 19, 2014Total posts : 2
Rohit Patel
Rohit Patel
Topic: Window Size
what should be the starting point for a toilet window from ground  floor.
Wed Feb 19, 2014Post  #1
Ahmed
Ahmed
Hi rohit
As for as in my knowledge, no body keeps windows in toilet.
ventilation /louvers ( 4 ft from floor) with provisioing for small exhaust fan
Thu Feb 20, 2014Post  #2
Dear patel
       The window in toilet should be from 4'-6'' high from floor level as per haryana  PWD norms.
Window Size
Last answer on 1/3/2014 1:07:20 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2431
Door Hinghes
Last answer on 12/28/2012 11:37:54 AM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
2606
Window position on wall
1392
Aluminium window misfit. need correction
Last answer on 7/3/2020 10:37:15 PM. by S L Gupta (Civil Engg). Forum started by Vishesh
1413
window size
Last answer on 2/18/2014 11:41:59 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1765
Window Size
Last answer on 2/21/2014 11:50:13 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2310
Can somebody help me with some real nice meditation room idea's. Room size is 15
Last answer on 2/8/2022 10:55:07 PM. by S L Gupta (Civil Engg). Forum started by PRIYAVADAN NAIR
2728
VENTILATION FOR BED ROOM
Last answer on 8/22/2013 5:28:15 PM. by GUNA. Forum started by bharati.pradeep7
2577
How to remove ton of sand from the basement with the help of vacuum pressure
Last answer on 2/11/2013 3:38:03 PM. by akmurty1. Forum started by ommu.sait
1613
Curtain size
Last answer on 7/6/2016 11:16:37 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
2108
Get me a elevation design for duplex house .ground floor with two large size win
Last answer on 7/3/2015 3:27:25 AM. by JAI PRAKASH. Forum started by Kundan Patel
2089
Laminate Glass for Wooden Windows
Last answer on 2/9/2014 5:04:29 PM. by Abhishek Garg (Builder & Engineer). Forum started by Ashok V
1801
floor plan
Last answer on 5/28/2013 4:58:51 PM. Forum started by oscar
3490
2800
Is it neceesary to have many windows and doors in kitchen as I have got only one
Last answer on 7/4/2020 2:44:00 AM. by PR Jawahar. Forum started by veena
2181
Comparing uPVC Windows with Wooden Windows and Aluminium Windows
Last answer on 9/11/2010 11:27:22 PM. by sachin. Forum started by Mahendra Agarwal
1926
Dutch Hood Canopy Awnings
Last answer on 1/24/2022 12:11:10 AM. Forum started by Shel Jones
2206
the Drawing Room window Curtains are a mismatch to the room size - blinds would
Last answer on 1/31/2022 3:01:18 PM. Forum started by Vanshri
5226
Right size cupola
Window
Window Treatments: Window Blinds for Windows
Know about the different styles of window blinds and add style with window treatments such as blinds, shades, curtains..
What is binding wire
