Mon Mar 10, 2014 | Total posts : 3 |
| Topic: With reference to civil structures, what are C-sections and I-sections ? When a
With reference to civil structures, what are C-sections and I-sections ? When are they used ? Are they used typically in renovation work and do they add significantly to construction costs ? |
Mon Mar 10, 2014 | Post #1 | Abhishek Garg (Builder & Engineer)
Join date: Apr 2013 | Dear Madhusudhanan: C-sections and I-sections, made of mild steel are usually used as a load bearing arrangement especially during renovation and nowadays, increasing in new construction as well. Here are the images of both of these types: C-section: http://tinyurl.com/pnqzh87 I-section: http://tinyurl.com/l99cmjx Do take help of a structural engineer before using them in construction. I hope it helps. | |
Fri Mar 14, 2014 | Post #2 | MADHUSUDHANAN AR
Join date: Sep 2008 | Post subject: With reference to civil structures, what are C-s...
thanks, Mr.Abhishek. In a sense, are these fabricated structures made of mild steel ? The related question was, does it add considerably to cost of renovation. Is it directly related to the price of steel ? Will take the help of a structural engineer as per your advise certainly !
Sat Mar 15, 2014 | Post #3 | Abhishek Garg (Builder & Engineer)
Join date: Apr 2013 | Dear Madhusudhanan: Yes, these are made of mild steel. During renovation, they are used where they create an easy solution to provide support/bear load of the existing structure. They are not super-expensive and have a direct relation to the price of steel. I hope it helps. | |
Articles that might interest you! | | Why question answer section was converted to a paid service? A lot of users have been asking why the question answer service was converted to a paid service and here are our thoug.. | | Guideline for Labor for Brick Work in Super Structure While going for construction, do we know the Guideline meant for Labor for Brick Work in Super Structure? If not then .. | | Building Architect vs. Structure Engineer It is very important to know the difference between architect and structure engineer if you are planning to construct .. | | Column and Frame Structure Building Columns are used to support the beam or roofs and transfer the load to the earth. These serve the decorative purpose a.. | | Earthquake Resistant Building Construction Earthquakes strike without much warning. It may harm badly designed & constructed buildings killing its inhabitants. T.. | | Termite Control “How to control Termite” is one of the main concerns in old as well as in new constructions. Termite damages the struc.. | | Make your home earthquake proof The following points should be kept in mind during construction of building for the protection against ‘Earth Quake’.
| | Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. | | Through rate-contractor; guidelines for better relationship! Everyone wants to build a dream home but no-one wants the hassle that comes in day-to-day construction work. Here are .. | | Various Waste Water Pipes (Sewer Construction) By providing a well managed system for waste water drainage we can enjoy a happy, healthy and pure life. Below is desc.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
