Home -> Forums -> Construction -> Start Construction -> about house map
about house map
Wed Dec 11, 2013Total posts : 2
vikash singh
vikash singh
Topic: about house map
i have a plot of 45*25 i want to construct a map.
Thu Dec 12, 2013Post  #1
Dear Vikash Singh
Thu Dec 12, 2013Post  #2
Post subject: PLANNING of house
Dear Vikas , Hello...! Kindly attach some more information about your plot  and Requirements to get a good planning for your House.like 1. Direction of plot.2.Front road width,3.construction on all 3 sides...regards.
2251
can i c house maps in this site
Last answer on 7/4/2009 6:35:50 PM. by Priti Arora. Forum started by kiran
9061
makan map
1820
I want 15 *50 square ft double house map
Last answer on 5/3/2016 11:33:57 PM. by JAI PRAKASH. Forum started by pravesh jain
2648
Please suggest house Map for ground floor plot Size 10x22.5 feet
Last answer on 8/4/2016 5:21:11 PM. Forum started by Gopal Upadhyay
6700
13*40 2 bhk 2 story east face .please mail the house map
Last answer on 7/4/2020 3:04:42 AM. by Beenu Phogat. Forum started by Devyani
7524
13fit wide and 80 fit length ka house map
Last answer on 7/4/2020 3:04:34 AM. by Beenu Phogat. Forum started by PANKAJ Kumar yadav
2242
i want 31*41feet house map plan
Last answer on 11/18/2021 6:08:30 AM. by S L Gupta (Civil Engg). Forum started by lasya123
1527
hlo sir, my plot size 15x45, please guide me a better house map.
Last answer on 9/2/2020 12:40:53 AM. by S L Gupta (Civil Engg). Forum started by pramod
2293
Kindly suggest ground plus 1 map for 120 Sq yards east open plot
Last answer on 7/4/2020 4:21:37 AM. by S L Gupta (Civil Engg). Forum started by Yousuf
3137
i want some samples house map 25X45(2bedroom,kitchen,drawing room)please send me
Last answer on 7/20/2015 12:01:25 PM. by seema tyagi. Forum started by mulchand
3157
2314
Dear sir by looking our house map could u pls tell us weather our house as per v
Last answer on 3/26/2013 6:39:15 PM. by Pavan. Forum started by Ramesh
16256
28.75*44.66 aria south facing plot. i have house map for this plot with vastusas
Last answer on 3/27/2017 12:19:04 PM. by S L Gupta (Civil Engg). Forum started by rambabuduey
1395
oh sir my plot is west facing what is proper house map according to vast with 2
Last answer on 11/20/2016 11:18:28 PM. Forum started by cm singh
15781
5335
Wanted to get House Map for 28 * 28* Sq. Feet Plot
Last answer on 5/28/2014 2:10:37 PM. by JAI PRAKASH. Forum started by Parshant
2085
Sir I have a plot length 55.9' and width 17.4' . Can u guide me for a house map
Last answer on 4/20/2015 12:31:34 PM. by seema tyagi. Forum started by Rakesh Singh
1114
I have a plot size25*50 south facing. Want to house map on this
Last answer on 7/4/2020 4:21:03 AM. by S L Gupta (Civil Engg). Forum started by Sushil
1421
Hello sir my plot size is 20×50 sq feet. I want house map with car porch
Last answer on 7/4/2020 4:26:04 AM. by S L Gupta (Civil Engg). Forum started by Arjun
4881
A Rough Idea for My House map
Last answer on 10/18/2014 5:37:54 PM. by Navneet Jharia. Forum started by b n lakhera
3312
2312
Painting
Environmentally
Environment
Environment Friendly Houses
Proper
Fireproof
Fireproof Home!
