Home -> Forums -> Construction -> Start Construction -> acrylic vs primer
acrylic vs primer
Tue Jan 20, 2015Total posts : 1
Topic: acrylic vs primer
Hi
what should  to use acrylic or primer after putty and before paint
Wed Jan 21, 2015Post  #1
Dear Paresh
          Primer give base for paint, so it is done before painting.
2991
Wall Putty ,primer and paint
4503
1825
wall primer
Last answer on 1/10/2016 9:04:01 PM. by JAI PRAKASH. Forum started by Anu
2361
estimation
2210
i need some dome designs for mosque in acrylic sheet with angle frame or alumini
Last answer on 10/5/2010 10:56:37 PM. by . Forum started by aslam
2956
2929
Plaster
2288
chowkets
Last answer on 9/16/2021 10:06:13 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
1693
3087
What type primer and paint should be used for concrete window and door frames?
Last answer on 6/5/2017 12:48:40 PM. by S L Gupta (Civil Engg). Forum started by vinu
13318
Marble Floor Comparison Required (Wonder Vs Katni Vs Dungri)
Last answer on 5/20/2014 12:04:53 AM. by Sunny Bansal. Forum started by Sunny Bansal
4349
rate comparison
5018
2849
I want tips of procedure of water primer on wall putty. When the water primer sh
Last answer on 7/8/2010 2:03:40 PM. by S L Gupta (Civil Engg). Forum started by Arup Ray
9541
Wall Putty and primer
3069
Painting
1469
What is best method to clean GI Door frames after cement plaster is over. If har
Last answer on 7/4/2020 3:19:44 AM. by Surinder Singh. Forum started by Surinder Singh
2022
How much White Cement will be required as Primer Coat on Fresh Raw Wall for appr
Last answer on 6/24/2013 3:01:38 PM. by S L Gupta (Civil Engg). Forum started by JAYANT VERMA
6532
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by S L Gupta (Civil Engg). Forum started by DK
3310
Paint
What is the raw material recommended for painting of metal surface?
Red oxide zinc chromate primer shall be used for iron and steel work including galvanized steel.Zinc chromate primer s..
Painting
