What are advantages and disadvantages of iron doors?
Sat Jan 30, 2010Total posts : 1
rajesh malik
rajesh malik
Topic: What are advantages and disadvantages of iron doors?
can you suggest me a mosquitoes net door which can serve dual purpose one to save from mosquitoes secondly save from rain water also and where can we buy in delhi
The comment above talks about the article   "What are advantages and disadvantages of iron doors?"
Sat Jan 30, 2010Post  #1
Post subject: Reply-What are advantages and
Dear Rajesh,
I have not seen such type of door shutters. The wire net used in the mosquitoes net is having 144 holes in one square inch. If door shutter is directly come in to contact with rain showers, then rain water penetrate through holes of mosquitoes net. If you want such type which can  prevent rain water to penetrate through  door shutters than you should take louvered door shutters and fix mosquitoes net on the inside portion of louvered door shutter this type of shutter can solve both the purpose. In this type of door shutters air circulation is less.
S.L.Gupta
please give images for iron door in front of main wooden door,
Last answer on 11/18/2013 3:27:52 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
2147
are iron doors expensive than pvc doors?
Last answer on 3/2/2014 5:40:13 PM. by Navneet Jharia. Forum started by neelam rathi
4348
rate comparison
18029
What are the advantage and disadvantages of FLYASH BRICKS?
Last answer on 10/18/2014 4:07:06 AM. by JAI PRAKASH. Forum started by gganesan
3928
7925
1702
Last answer on 7/3/2020 11:20:06 PM. by S L Gupta (Civil Engg). Forum started by PCR.Manohar
2495
images of iron gate attached to main door
Last answer on 11/18/2013 4:05:44 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
3371
What are the advantages of double leaf doors ?
Last answer on 7/3/2020 10:02:28 PM. by JAI PRAKASH. Forum started by Arvind Bhaskar
1933
Advantages and disadvantages of Steel doors and windows?
Last answer on 11/24/2016 12:19:49 PM. by S L Gupta (Civil Engg). Forum started by vinu
1938
Is it necessary to put iron wire under tiles at enterance of all doors in house?
Last answer on 9/18/2013 3:11:29 PM. by S L Gupta (Civil Engg). Forum started by bakula
2253
Sreel pillars(post)
2891
self made steel home
Last answer on 5/28/2012 8:26:15 AM. by smithjames758. Forum started by Govind.s
2568
Which are advantages and disadvantages of POP?
Last answer on 9/27/2009 5:08:03 PM. by Gunjan Utraja. Forum started by nkj
3492
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
13271
What is the advantage and disadvantage of using Robo Sand (stone crush) in RCC a
Last answer on 10/17/2014 9:27:21 AM. by SANJAY DUSANE. Forum started by Ajith Prakash
2157
8247
what are the disadvantages of flyash bricks?
Last answer on 12/31/2020 2:29:47 AM. by H S Rathi. Forum started by gganesan
1916
Tips on Iron chukhat
Last answer on 8/5/2011 12:07:32 PM. by S L Gupta (Civil Engg). Forum started by Reena Sareen
Advantages
What are the advantages and disadvantages of Aluminium doors?
ADVANTAGES:Strength, stability, weatherproof qualities. DISADVANTAGES: Quick oxidation, easily water stained...
What are the advantages and disadvantages of flush doors?
Advantages of flush doors-offer simplicity in design, attractive appearance, durable, good stability against twisting...
What are the advantages and disadvantages of plastic/PVC doors?
Plastic Doors-Termite proof ,tough and durable ,anti corrosive ............
What are the advantages and disadvantages of crazy marble flooring?
Crazy marble flooring is more durable and has refined, regal, decorative appearance..........
What are the advantages and disadvantages of marble flooring?
The marble flooring is more durable...
What are the advantages and disadvantages of glass windows?
Glass windows offers superior Transparency has to be balanced with its relatively low R-value.
Advantages
