Home -> Forums -> Construction -> Fine Sand -> alternative for river sand
Sat Jun 11, 2011Total posts : 2
sudakar
sudakar
Topic: alternative for river sand
Please let me know what alternative is possible in tamilnadu for river sand.  Please also advise regarding cement plastering and pop application in inner walls of the rooms in order to put the cost down without comprimising strength
Sat Jun 11, 2011Post  #1
Swati Sharma
Swati Sharma
Post subject: Alternative for river sand
Hey Sudakar,
If you are having dificulties with river sand you can opt for Gypsum stucco plaster and it can be used without morter.
Regards:
Swati Sharma.
Sat Jun 11, 2011Post  #2
Dear Sudhakar
   You shoud go with gypsum plaster which will save the cost and time. As it gives finishing in one coat for more detail see the link given below.
http://www.gharexpert.com/articles/POP-2134/Gypsum-plaster-Plaster-Paris-_0.aspx
If you want more information about construction go to website gharexpert.com wher you will find lot about construction and interior.
Fine Sand-Construction Questions (27)
7221
Alternative to river sand for wall plastering jobs
Last answer on 1/7/2011 3:36:01 PM. by jaydeep. Forum started by S. Krishnamoorthy
3721
3014
M-Sand for Plastering
1772
1464
2106
river sand
2752
6459
16079
robo sand vs natural sand
3496
Robo Sand for Brickwork
2140
2039
Alternate for River Sand
Last answer on 2/25/2013 2:02:46 PM. by RENJI. Forum started by RENJI
3231
Would like to know is it correct to use the M.Sand instead of river sand for the
Last answer on 10/30/2010 2:10:01 PM. by S L Gupta (Civil Engg). Forum started by kcantony
3619
Can we use crushed Sand for house construction
Last answer on 4/8/2014 12:28:09 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2684
2015
coarse aggregate
7010
2333
Sand units
1710
Sand units
2199
2333
Sand units
1710
Sand units
1529
Sand units
3014
16079
2039
2814
sand wight per cu.feet
Last answer on 11/5/2012 11:47:35 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
Swimming
Swimming Pool Filters
Through
How To Repair Cracks
