Home -> Forums -> Construction -> Start Construction -> basement construction
Tue Sep 16, 2008Total posts : 4
rahul
rahul
Topic: basement construction
can anyone elaborate upon the method of constructing a semi basement
i.e. 6 feet down &3 feet above G.L. about the foundation & side walls
and if possible the reinforcement required with r.c.c.for building
having semi basement plus two stories.
Tue Sep 16, 2008Post  #1
Post subject: Basement Construction
For construction of semi-basement building, you should clear the earth 6 feet deep from ground level. Then start the process of foundation and other components as usual. For basement side walls treatment, you can click on the link given below for help.
http://www.gharexpert.com/articles/Basement-1504/Basement_0.aspx?PL=2&ArticleID=1504&CatID=1120
If you want structural details, send us architectural drawings. Our structural engineer will design your building plan at prevailing market rate. He will provide you following details.
1)    Size of column, walls and there foundation details i.e. width and depth of the foundation,
2)    Earth quake measure
3)    Details of beams, R.C.C slab and arrangement of mild steel bars according to loading.
Sun Sep 21, 2008Post  #2
s.m.sudhan
s.m.sudhan
Post subject: Basement construction
Can someone inform what is thumb rule cost for basement construction?
Thu Sep 25, 2008Post  #3
Deepti
Deepti
Post subject: Basment Construction Cost Estimation
For the cost of the basement one should calculate the items required for the basement, according to the need and specifications used in construction of basement. It can be calculated with the help of cost estimator in the website gharexpert.com. Generally, the rate for construction of basement is approximately Rs. 400 per Sq ft to Rs. 450 Sq ft.
Thu Sep 25, 2008Post  #4
Kanhaiya
Kanhaiya
Post subject: Basement Construction?
Is it a good idea to construct basement in India? I would think flooded basement would be common in India (with the amount of rainfall India gets). Will the foundation hold?(due to shifting ground)
In Gujarat, I have rarely seen people constructing basement in their house. I have heard person making a wonderful house with basement type parking. Only to see it flooded during rainy season. Now he is trying to sell the the house.
4246
Last answer on 7/3/2020 11:17:06 PM. by Kanhaiya. Forum started by rahul
2416
Last answer on 8/3/2010 4:41:04 PM. by Prabhakar. Forum started by asdaasd
2712
BAsement construction
Last answer on 11/8/2012 5:34:56 PM. by sheree123. Forum started by Gagandeep
2160
Cost of Basement Construction
Last answer on 3/19/2015 12:35:24 AM. by JAI PRAKASH. Forum started by kuljit singh
1432
Last answer on 3/19/2015 12:32:55 AM. by JAI PRAKASH. Forum started by kuljit singh
4211
Selection of cement ..
2016
Basement Construcyion
Last answer on 6/16/2011 7:38:32 PM. Forum started by Pragalbh
2708
2564
Last answer on 3/2/2015 12:09:44 PM. by seema tyagi. Forum started by Alok
5793
Last answer on 8/20/2020 3:44:33 AM. by S L Gupta (Civil Engg). Forum started by mayank
2463
Basement - Type and Cost
Last answer on 12/10/2013 12:01:40 PM. by S L Gupta (Civil Engg). Forum started by Ali
1363
SirAfter construction of the basement slab, can the pillar work for the ground f
Last answer on 9/4/2017 12:35:46 AM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
1481
Construction of house with basement.
Last answer on 5/10/2016 11:38:09 AM. by S L Gupta (Civil Engg). Forum started by MUSHAHID RAZA
1652
1367
Can I make a basement in the face of North East side plot
Last answer on 1/6/2017 12:06:38 PM. by S L Gupta (Civil Engg). Forum started by Mantu
1815
Last answer on 8/15/2015 8:17:49 PM. by JAI PRAKASH. Forum started by Devender
2189
Last answer on 11/18/2013 10:57:21 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
1922
Last answer on 11/18/2013 10:38:53 AM. by S L Gupta (Civil Engg). Forum started by adari haripraveen
2486
Last answer on 9/20/2010 8:49:58 PM. Forum started by A Prasad
3312
2312
Basement Design Ideas
Vastu Guidelines for Basement
Basement Ceiling
Basement Flooring
Basement Interior Design
