Fri Sep 07, 2018Total posts : 2
Muhammad
Muhammad
Topic: What are the benefits of using TMT bars for construction of homes
Mon Sep 10, 2018Post  #1
MT Bars (Thermo Mechanically Treated Bars)
TMT Bars,Thermo mechanically treated bars are high strength deformed steel bars used in reinforced cement concrete (RCC) work manufactured with the help of advancement of technology. TMT bars are latest production in MS steel bars and have superior properties such as strength, ductility, welding ability, bending ability and highest quality standards at international level.
What is thermo mechanically treatment process?
By adopting thermo mechanically treatment process higher strength of TMT bars is obtained. In this process, steel bars get intensive cooling immediately after rolling. When the temperature is suddenly reduced to make surface layer hard, the internal core is hot at the same time.  Due to further cooling in atmosphere and heat from the core, the tempering takes place. This process is expected to improve properties such as yield strength, ductility and toughness of TMT bars. With above properties, TMT steel is highly economical and safe for use. TMT steel bars are more corrosion resistant than Tor steel.
How to get higher strength of TMT bars?
Generally, higher strength of TMT bars can be obtained by increasing carbon content, micro alloying, and thermo mechanically treatment or cold twisting. So far in India, cold twisting of bars is extensively used for the production of high strength bars. The two main ribs become helical when cold twisting process is done whereas these ribs in hot rolled bars are straight. The excess of carbon content threatens its property of welding ability.
In TMT bars, this problem has been eliminated. In these bars, carbon content has also been brought down leading to improved ductility and can be restricted to 0.2% to attain welding ability and at the same time no strength is lost. The joints can be welded by ordinary electrodes without any extra precautions.
Features of TMT Bars
  • Better ductility and malleability
  • High yield strength and toughness
  • More bonding strength
  • Earthquake resistance
  • Corrosion resistance
  • High thermal resistance
  • Economical and safe in use
  • No loss in strength at welded joints
  • Ordinary electrodes used for welding the joints
Caution
  • While purchasing TMT bars, notice identification mark on these bars from manufacturing firm.
  • For big projects it is advised to check that only one type/grade of bars is brought to the site and is used in the project after conducting test for each lot. Do not use mixed, 2 or 3 types/grades bars in RCC work at one work.
Mon Sep 10, 2018Post  #2
      Addition to above
High strength deformed bars IS: 1786-1985 are steel bars which are provided with lugs, ribs, projection or deformation on the surface and are produced in form of cold twisted deformed bars. These bars are extensively used for reinforcement purposes in a construction. Due to ribs or projections on the surface, these steel bars minimize slippage in concrete and increase the bond between two materials i.e. between cement concrete and steel bars.
The deformed bars have more compressive and tensile stress than that of mild steel plain bars. High strength deformed bars have improved anchorage; therefore they can be used without end hooks or bent up ends of bars. This reduces labor for fabrication of steel reinforcement.  The deformation is spaced on bar at uniform distances. These bars are produced in sizes or sections from 4 mm to 50 mm in diameter.
Generally cracks develop in reinforced concrete around mild steel bars due to stretching of bars, loss of bond under the load. To minimize this problem, deformed bars having projecting ribs or twisted surface which improves the bond with the concrete should be used in RCC work.
Features of HSD Bars
  • Low carbon value: HSD Bars have lower carbon level, resulting in good ductility, strength and welding ability.
  • Superior bonding strength: HSD bars are well known for their excellent bonding strength when used with concrete.
  • Welding capability: Since these bars have lower carbon content, they have 100% welding capability than conventional bars.
  • High tensile strength: HSD bars feature high tensile strength. They offer great asset in construction process, where a lot of bending and re bending is required.
  • Wide application range: These bars have wide application range like in building residential, commercial and industrial structures, bridges, etc.
  • Satisfactorily malleability, minimum weight and maximum strength and suitable for both compression and tension reinforcement.
Process of production of bars
The main process for production of bars is hot rolling followed by cold twisting. Latest technological advances in the field of micro-alloying of steel and thermo-mechanical treatment process have resulted in the production of deformed bars as reinforcement for use in cement concrete in three grades namely Fe 415, Fe 500 and Fe 550.
The strength of bonds of deformed bars
In addition, the calculated strength of bonds of deformed bars should be 40 to 80 % higher than that of plain round bars of same nominal size. Tor steel possesses the strength of 1.5 to 2.0 times of mild steel in compression as well as in tension, whereas it costs only 10% more than mild steel.
Deformed steel bars have minimum 0.2% proof stress or yield stress in N/mm square. Proof stress is the stress at which non proportional elongation equal to 0.2% of the original gauge length takes place. Hence deformed steel bars are very economical to use in RCC work. Structural Engineer recommends cold twisted deformed (Ribbed or Tor Steel Bars) bars as they are best quality steel bars for construction work.
Mechanical properties of high strength deformed (HSD) steel bars for concrete reinforcement
Property Grade of Steel
 Fe415        Fe500           Fe550
0.2% proof stress/ yield stress minimum N/mm square415.0         500.0            550.0
Elongation, percent minimum on Gauge length 5.65 VA where A is the cross sectional area of the test piece
14.5           12.0               8.0
Tensile strength, minimum, N/ mm square10% more than proof stress but not less than 485, 8% more than proof stress but not less, than 545, 6% more than proof stress but not less than 585
3037
use of tmt bar
1528
1400
1502
3752
2611
1271
1740
1255
Is HYSD steel bars still used for construction. Do they meet the safety standard
Last answer on 1/10/2019 12:18:04 AM. by S L Gupta (Civil Engg). Forum started by rinu
2507
4069
steel requirement
2626
Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Last answer on 9/30/2016 2:16:48 PM. Forum started by vinu
2001
2971
duration of constucting home
1631
1788
Dear sir/madami am building a house in coastal part of goa.need advice from expe
Last answer on 10/11/2015 8:43:58 PM. by JAI PRAKASH. Forum started by prasad K
1163
When we bought TMT bars for house, they said it was anti-rust. We had to stop ou
Last answer on 8/19/2018 11:54:21 PM. by S L Gupta (Civil Engg). Forum started by Vineeth V
2218
For 1850 sq.ft flat roof ,what mm tmt bars used my hall size 21*21 and 11*17 and
Last answer on 8/1/2018 11:18:57 PM. by S L Gupta (Civil Engg). Forum started by satheesh
TMT
Brass
Brass Doors
Brass doors are very popular for Georgian and Victorian types of architecture in ancient buildings. Today brass doors ..
HSD
Type
