Home -> Forums -> Construction -> Start Construction -> Which is the best terrace water proofing ?
Wed Sep 07, 2016Total posts : 3
Satvinder kaur
Satvinder kaur
Topic: Which is the best terrace water proofing ?
Which is the best terrace water proofing and weather proofing method?
Thu Sep 08, 2016Post  #1
          Economical, Simplest and easy terrace water proofing is
               Clean and dry the roof surface than apply hot bitumen @ 1.65 kg per square meter than lay polythene sheet on bitumen surface while some what hot.
Lay 1'' thick mud faska that mud with tura.
After this lay good earth accordingly to maintain proper slope rammed and lay brick tiles with mud. After that grout the surface with cement coarse sand mortar 1;3.
If needed do 1;2 flush cement pointing and cure it at least for 7 days.
Fri Sep 09, 2016Post  #2
bhuvaneshwaran bn
bhuvaneshwaran bn
To Avoid leaks thru Roof or beam column joints.
I suggest You to consult The expert like Dr.fixit or Fosroc.They are best in the Market and the Advice you on water Proofing Problems.
Wed Sep 21, 2016Post  #3
Pawan kumawat
Pawan kumawat
you can use puddlo and impermo water prroffing
2897
Terrace water proofing
2303
2341
lift pit water proofing
roofing on open terrace
2233
3163
APP membrane
1800
2236
2400
2319
Water proofing method
2340
Waterproofing leaks from terrace
Last answer on 5/15/2015 11:08:13 AM. by prit123. Forum started by island
10048
1736
best reliable & surge proof l ed light fittings for indian homes
Last answer on 9/22/2013 1:50:16 PM. Forum started by sanjeev tiwari
3828
ROOF WATER PROOFING / TANKING
3076
Water Harvesting System
Related to Sunken Slab
1844
2762
5170
3312
2236
2312
2061
Roof Garden
Damp
Damp Proofing
Protect
Preventive
Fire
Basement Design Ideas
Guideline for laying DPC
Earthquake
