| "KITCHEN"THE POWER HOUSE SOUTH-EASTCORNER IS SUPPOSED TO BE THE PLACE OF LORD AGNI,GOD OF FIRE. |
| Through rate-contractor; guidelines for better relationship! Everyone wants to build a dream home but no-one wants the hassle that comes in day-to-day construction work. Here are .. |
| Terrazzo flooring (Mosaic or Marble chip flooring) Terrazzo flooring is popular for residential as well as public buildings since it is not slippery when wet.
How to level concrete sub floor before installing wooden block flooring? The recommended method for leveling of concrete in wooden block flooring is described in the writeup. |
Refinishing Hardwood Floors When you feel that the finishing of the floor is out of fashion or you are getting bore of it, refinish your old hardwoo |
Checklists for flooring While going for any construction everyone needs some handy points on every stage of construction so as in while laying.. |
| Comparison between Basement and Additional Upper Floor Construction of basement and multi storey building is the need of the hour as there is less availability of land and r.. |
| Appropriate Flooring for different Locations The type of flooring you choose depends on the location you are using it for. But if you are confused about the select.. |
| Linoleum Flooring Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color .. |
| Vinyl Flooring Are you looking for unbreakable, flexible and non porous flooring? Vinyl flooring or PVC flooring is the best choice. .. |
