Home -> Forums -> Interior -> Bedroom -> better way of laying electrical wires
Wed Apr 30, 2014Total posts : 2
ajaywahi
ajaywahi
Topic: better way of laying electrical wires
Is it better to lay conduits (for carrying electrical cables) while casting roof or underground ( marble /stone) or false ceiling?
Could you advise the pros and cons of each of the 3 options:
1. While casting roof
2. Underground before laying marble
3.  Before False Ceiling being done?
Ajay 9810027979
Wed Apr 30, 2014Post  #1
Dear Ajay
       Conduit pipes is better if you laid during the RCC slab.
It is equally good before false ceiling but some time their fitting may be loose.
 Conduit should not be laid under floor.
Under floor there is problem of sanitary and water line , which cause leakage at any time.Also crossing of line is creates problem.
Wed Apr 30, 2014Post  #2
ajaywahi
ajaywahi
Dear Mr Gupta,
Many thanks for your advise. Actually for every room, we have laid one 25 mm while RCC slab being done but to be on safe side, i am putting one more 25mm pipe in False Ceiling!
When you say, they may loose, means I need to ensure they are tightly clamped to avoid lose?
Best
AW
2962
3086
1960
2022
2466
2274
Ac and Electrcial
1524
2337
electrical installation
Last answer on 11/27/2021 2:32:14 AM. by Navneet Jharia. Forum started by brajesh pandey
2849
2507
2002
Electrical Conduits
Last answer on 4/30/2014 3:32:30 PM. by ajaywahi. Forum started by ajaywahi
1921
electrical work in house
Last answer on 9/4/2021 6:00:39 AM. by JAI PRAKASH. Forum started by milind
1502
2015
Dear Mr.S.L Gupta, I am currently constructing a house. Marble has b
Last answer on 5/5/2014 2:31:18 PM. by PR Jawahar. Forum started by Anurag
1511
Electrical wiring
Last answer on 11/1/2015 6:41:12 PM. by JAI PRAKASH. Forum started by ani
2303
Electrical Wiring
Last answer on 5/16/2013 12:22:40 PM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
2876
Last answer on 9/30/2020 7:45:37 AM. by Vijay Mishra. Forum started by SCK
11692
2567
cost of electrical
6073
20×60
2028
2606
1805
i need to learn 3ds max
2201
Flat interiors
3624
Wall unit
3470
paint
2574
waterproofing
2540
2548
2509
very nice interior
3143
course interiordecoration
2557
Bye Law
6427
3d max
2579
2372
3186
1647
2321
super
2239
Bed design is this best !
Electrical
Electric
Electric Shock Proof Home
Earthing
What is binding wire
Electric
Electric
