Home -> Forums -> Construction -> Basement -> brick
brick
Fri Dec 27, 2013Total posts : 1
abdul wahid laskar
abdul wahid laskar
Topic: brick
can you tell me in 13.5 x 13.5 room approx how many bricks needed in one room. .. and for plastering how many cement bags required in outside and inside the room.
2.why is 8mm and 10 mm rod needed in slab.. .. the contractor told me that they will make two Nets of them what's that
Mon Dec 30, 2013Post  #1
Dear Abdul
       The quantity of bricks is related to thickness of wall  and height of wall,however 6500 nos bricks approximately required and cement required 15 bags.
Basement-Construction Questions (40)
2949
2863
FLYASH OR CLAY BRICK
2688
type of brick
3917
4163
GLASS BLOCKS / BRICKS
4023
2339
2357
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Last answer on 7/9/2012 3:21:23 PM. by Ar. Manoj Ralen. Forum started by Lynda
2851
Bricks
3976
2404
2007
7497
Brick Advice Urgent
3028
Last answer on 8/18/2011 6:51:51 PM. by prasadtvp. Forum started by chella earnest
8236
what are the disadvantages of flyash bricks?
Last answer on 12/31/2020 2:29:47 AM. by H S Rathi. Forum started by gganesan
6274
brick tile tracing
Last answer on 7/4/2020 2:14:39 AM. by S L Gupta (Civil Engg). Forum started by rahul
3418
2862
35137
9051
makan map
2757
17206
1978
2146
design of column
2263
2243
Underground water tank
2639
2753
foundation
2022
Full Plan Needed
3183
labour cost
3152
APP membrane
2788
1961
ffff
1860
4177
Selection of cement ..
3454
2002
Regarding construction
3144
Basement Water proffing
2002
Acid staining
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
