Bricks
brick calculation
brick calculation
Tue Oct 14, 2014
Gagandeep
Topic: brick calculation
Want to make 3' high 10" wall.
How to
calculate
the requirement of
bricks
and other material.
Pls
help
Tue Oct 14, 2014
Dear Gagan Deep
For 10' long 9'' thick and 3' high wall bricks will be required=300 nos bricks and cement= 1bag and sand is 6 cft.
Wed Oct 15, 2014
Gagandeep
Thanks A lot Gupta Sir.
Thu Oct 16, 2014
Correct
4797
Last answer on 1/13/2014 2:23:28 PM. by
balaji
4331
Last answer on 3/15/2011 6:15:21 PM. by
Mohini Sharma
kanwer sajjad
2992
2017
Last answer on 8/4/2011 2:42:26 PM. by
BEN
2159
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by
arctushar
1965
I have constructed my house thru one of local contrctr at the rate of 1300 per s
Last answer on 12/4/2014 1:21:13 AM. by
mani
2873
FLYASH OR CLAY BRICK
Last answer on 12/3/2013 11:46:22 AM. by
Abhishek
2707
type of brick
Last answer on 12/5/2013 11:14:47 AM. by
neelam rathi
3928
Last answer on 7/28/2015 11:31:41 PM. by
nithin
2350
Vikas
4056
Last answer on 7/26/2012 12:16:09 PM. by
sanjay kumar makhija
4179
GLASS BLOCKS / BRICKS
Last answer on 11/10/2021 8:22:17 PM. by
Girish
Girish
2025
2364
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Last answer on 7/9/2012 3:21:23 PM. by
Ar. Manoj Ralen
Lynda
2865
Bricks
Last answer on 1/16/2013 11:34:07 AM. by
shahidain
3992
Last answer on 7/25/2013 5:11:37 PM. by
LAKWINDER
shahidain
2417
Last answer on 10/20/2013 8:17:05 PM. by
sowmya
sowmya
7513
Brick Advice Urgent
pmarple
pmarple
3433
amit yadav
amit yadav
7513
Brick Advice Urgent
pmarple
pmarple
2879
Bricks
Chandrasekaran S
2565
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4894
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2821
srinu
2350
Vikas
3172
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5658
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3238
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5135
Use of Solid Concrete Bricks
aravind
Kinley Tshering
1624
Last answer on 1/20/2017 3:47:17 PM. by
1341
Last answer on 1/16/2017 3:05:19 PM. by
1846
Last answer on 11/3/2016 2:26:29 PM. by
1479
Last answer on 8/24/2016 12:13:52 PM. by
1797
2966
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2230
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1723
Techman
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
