brick tile tracing
brick tile tracing
Mon Aug 25, 2008
rahul
Topic: brick tile tracing
what is brick tile tracing on roof
Thu Aug 28, 2008
Deepti
Post subject: Brick Tile Tracing Layout Procedure
To lay brick tiles with mud mortar on rammed earth over mud Phuska on RCC slabs painted with bitumen and the joints of tiles grouted with cement mortar and clean with wire brush or brooms is called tile tracing on roof.
Layout Process
• After RCC slabs are thoroughly dried, they should be cleaned with wire brush and broom etc.
• The surface of slabs should be painted with hot bitumen @ 1.7 Kg. per square meter.
• After painting, immediately clean coarse sand is spread on the surface at the rate of 0.60 CUM per 100 square meters on the surface of roof so that bitumen layer is not damaged during subsequent work.
• One layer of 25 mm thick mud plaster mixed with Bhusa should be laid.
• Damp soil should be laid on the roof to the required thickness and slope. The slope should be between 1 in 50 and 1 in 60. Minimum thickness of the soil should be about 25 mm near rain water pipe.
• The soil should be compacted with wooden rammer to obtain an even surface to correct slope.
• Another coat of 25 mm thick mud plaster should be laid on compacted earth.
• Flat brick tiles of size 22.86X11.43X3.81 Cm. are laid on mud plaster to correct slope. It should be ensured that a mud plaster does not come into vertical joints of tiles by more than 12 mm.
• The thickness of joints in tiles should not be less than 6 mm and more than 12 mm in width.
• After drying of mud mortar the joints of tiles should be grouted with cement mortar 1:3 and ensure that all joints of tiles are completely filled with mortar.
• The surface of brick tiles is then checked for evenness and slope by means of straight edge and spirit level.
• If any unevenness found, it should be rectified immediately.
• As soon as cement grouting obtain initial setting, the surface of brick tiles should be covered with gunny bags to prevent quick drying of cement mortar in joints.
• After 8 to 12 hours, brick tiles paving should be cured by frequent sprinkling of water on the surface for a period of 7 days.
Tue Oct 02, 2018
Thank you.
1852
Last answer on 12/24/2015 4:17:23 AM. by
paramesh
3475
labour charges rates
Last answer on 7/4/2020 2:03:37 AM. by
SAGAR
2691
Brick tile flooring
Last answer on 7/13/2020 12:31:14 AM. by
Vinay
2498
removing screed on brick tiles
Last answer on 7/13/2020 10:37:59 PM. by
chander
3606
What is the SCALE of Khasra Trace
Last answer on 6/10/2019 1:06:25 AM. by
Ashish
Last answer on 7/11/2020 8:09:13 PM. by
Vinay
Vinay
3075
Last answer on 8/27/2015 6:47:23 PM. by
Allwyn
5324
Last answer on 10/8/2015 1:01:18 AM. by
nancy
2991
2017
Last answer on 8/4/2011 2:42:26 PM. by
BEN
4041
How to Apply Ceramic tiles on roof Terrace
Last answer on 12/3/2011 10:27:48 PM. by
newtondisc
Pooja Panchal
2323
Please let me know difference between vetrified tiles and porsoline tiles.
Last answer on 7/2/2010 3:30:35 PM. by
jyoti
Sudhakar
4179
GLASS BLOCKS / BRICKS
Last answer on 11/10/2021 8:22:17 PM. by
Girish
Girish
4054
Last answer on 7/26/2012 12:16:09 PM. by
sanjay kumar makhija
3223
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by
Jemimmarichardson
aammiitt
2349
Vikas
2849
Last answer on 7/23/2013 11:24:40 AM. by
g madhusudan
JANCYSABU
2873
FLYASH OR CLAY BRICK
Last answer on 12/3/2013 11:46:22 AM. by
Abhishek
2705
type of brick
Last answer on 12/5/2013 11:14:47 AM. by
neelam rathi
Reasons of dampness
Brick Tiles
Flat Brick Tiles should confirm specifications as per IS-1077-1992 and must be homogeneous in texture.
Tiles for Bathroom
Brick Arches
