Home -> Forums -> Construction -> Bricks -> building material
building material
Fri Nov 14, 2014Total posts : 1
dbg
dbg
Topic: building material
  1. I want to construct   first floor measuring 670 sq. Ft . what will be required building material?
Attachments: New Microsoft Office Word Document.docx on Fri Nov 14, 2014,&n
Sat Nov 15, 2014Post  #1
Basic Material: (Just as Assumption)
Saria – Around 1-1.2 tonne
Dust – 450-500 ft
Rodi – 250-300 ft
Cement – 150-200 bags
Bricks – 18000-20000
Reti - 200 ft.
1914
building material
Last answer on 3/23/2015 10:00:27 PM. by JAI PRAKASH. Forum started by shaheryar
1832
Reg: Building materials and their costs
Last answer on 12/24/2013 12:02:23 PM. by S L Gupta (Civil Engg). Forum started by Dhananjay
2336
Last answer on 9/19/2012 1:30:40 PM. by r s rawat. Forum started by mujahedsabb
2392
BUILDING MATERIAL RATES & PETTY JOB RATES
Last answer on 5/15/2013 12:16:14 PM. by GULSHAN RAI GULATI. Forum started by GULSHAN RAI GULATI
28823
latest price of building materials in bangalore
Last answer on 10/10/2010 12:44:43 PM. by rudresh. Forum started by manjuks
2624
Building material
Last answer on 10/19/2010 4:32:40 PM. by . Forum started by kamalesh
1541
Where should i enquire good quality building material?
Last answer on 6/1/2013 11:58:15 AM. by S L Gupta (Civil Engg). Forum started by ananth
2096
specifications of building materials used in construction industry
Last answer on 9/6/2015 12:27:20 PM. by sanjay agarwal. Forum started by Star Koziba Leladi
1968
Construction of a new house
Last answer on 7/5/2012 2:07:00 PM. by Gunjan Utraja. Forum started by Sandeep Sethi
1885
can i get the plans and material list would like to build this
Last answer on 6/18/2012 3:25:01 AM. by Gunjan Utraja. Forum started by Jeremy
7232
2 lakh litre water tank
2208
Looking for expert advice
Last answer on 9/16/2014 11:09:25 PM. by Ced Bowen. Forum started by Ced Bowen
3304
GFRC Construction
2537
Function Hall
3845
comments required
Last answer on 11/18/2021 7:51:18 AM. by Gunjan Utraja. Forum started by gangula
2557
1749
What are the item excluded if i choose only labour contract.
Last answer on 5/24/2013 3:11:45 PM. Forum started by ananth
2821
building a house
2302
7513
Brick Advice Urgent
2879
Bricks
2794
brick calculation
2565
Cost of Brickwork
4894
2821
2350
3172
bricks
5659
3238
5135
Use of Solid Concrete Bricks
1624
1341
1846
1479
1797
2966
fly ash bricks
2230
1723
Fire
Comparison
Orientation
Orientation of Building
How to Build Stair Steps
Cupola Proportions
Tips for cupola proportions
How To Repair Cracks
