Home -> Forums -> Construction -> Start Construction -> can I use 6mm TMT bar fe 415 instead of 8MM TMT bar in coloumn and beam
Mon Jun 03, 2013Total posts : 1
venkatesan.pt.
venkatesan.pt.
Topic: can I use 6mm TMT bar fe 415 instead of 8MM TMT bar in coloumn and beam
I need your recommendation to use 6mm rods instead of 8mm roads for coloumn and beam for residential flats
Kindly send yours views to my mail ID venkatesan.pt@margproperties.com
Tue Jun 04, 2013Post  #1
Dear Venkatesan
         Use 8mm dia bar for ring/ ties of columns and beam and the spacing should be according to the structural drawing for taking full strength of RCC.
1530
1622
3754
1589
1503
2613
2628
Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Last answer on 9/30/2016 2:16:48 PM. Forum started by vinu
1200
Hi,TMT grades like Fe 550 and Fe 550D, what makes Fe 550D more ductile. Why is t
Last answer on 2/19/2019 11:14:50 PM. Forum started by Vineeth V
24767
3039
use of tmt bar
1166
When we bought TMT bars for house, they said it was anti-rust. We had to stop ou
Last answer on 8/19/2018 11:54:21 PM. by S L Gupta (Civil Engg). Forum started by Vineeth V
9363
3225
Size of TMT bar for RCC main slab and beam
Last answer on 1/27/2017 3:25:08 PM. by Rahul. Forum started by Rahul
4071
steel requirement
13772
overlap length to steel
2037
2708
2302
2033
3312
2236
2312
2061
TMT
HSD
Type
Dining
Dining Chairs and Bar Stools
Hard
Precautions
