Tue May 06, 2014Total posts : 3
mohammed sadhiq ali
mohammed sadhiq ali
Topic: can v fix vetrifed tiles inside the underground water tak or sump
Tue May 06, 2014Post  #1
Dear Ali
          Yes you can  Fix ceramic or vetrified tiles in under ground water storage tank.
Mon Oct 13, 2014Post  #2
you can fix any type of ceramic tile, but vitrified tiles are costly go for ordinary any ceramic tile. Also check leakage of tank before fixing tiles
Thu Oct 16, 2014Post  #3
Special tiles are available for tank.
3370
6583
5734
4386
Last answer on 7/4/2020 2:05:07 AM. Forum started by NV MANI
3080
Last answer on 1/2/2021 5:22:54 AM. Forum started by NV MANI
2534
what happens when sump comes at north east corner inside the room
Last answer on 7/3/2020 10:54:04 PM. by S L Gupta (Civil Engg). Forum started by vedamurthy
2492
is these lights fixed inside the wooden boxes?
Last answer on 3/3/2011 9:03:23 PM. by Nenni. Forum started by meenu
3500
3120
2445
Underground sump finished with granite/tiles
Last answer on 12/26/2014 2:16:16 PM. Forum started by am.sridhara
2483
2188
1609
Which colour of floor tiles should be fixed as per vasthu
Last answer on 3/14/2017 12:10:29 PM. by S L Gupta (Civil Engg). Forum started by Subbu
2374
underground water sump
Last answer on 9/10/2021 2:04:05 PM. by JAI PRAKASH. Forum started by prashanth a
1996
Hi. I have built a Fresh water underground sump in the South east corner of the
Last answer on 3/1/2011 3:05:47 PM. by Mohini Sharma. Forum started by m naveen
40520
5462
Underground water sump
Last answer on 2/27/2015 11:50:23 AM. by revadi. Forum started by hb
2043
Underground Water storage
24
28
Vastu for Water Tank
Tile
Tiles
Tiles for Bathroom
Designing
