Fri Aug 06, 2010Total posts : 6
nancy
nancy
Topic: can vitrified tiles be installed on existing mosaic tiles, or do the mosaic tile
can vitrified tiles be installed on existing mosaic tiles, or do the mosaic tiles need to be removed.
Thu Jun 06, 2013Post  #1
Post subject: vitrified tiles be installed on existing mosaic ...
Dear Nancy, hello, It is possible to laying Vitrified tiles on Mosaic floor/Mosaic Tile ,But Remember ...you have to cut the Door shutters according to floor's thickness....If it is not  easy then go for removal of Mosaic tile Flooring...
Thu Jun 06, 2013Post  #2
Better remove old mosaic floor
Sat Aug 01, 2015Post  #3
Anuj Aggarwal
Anuj Aggarwal
Hi Nancy:
The question is whether one can have good adhesion between the existing mosaic flooring and vitrified tiles. It is cheaper to modify the base with grinding existing mosaic flooring for better adhesion and then have a cement layer to which the vitrified tiles can bond to. If done properly, there is no deterioration in performance of the vitrified tiles. The door shutters will have to be cut say 0.5 inch. That generally is not a problem unless and until you are using Flush Doors.
-Anuj Aggarwal
Wed Aug 05, 2015Post  #4
It can be installed but not stay for long time, good to remove mosaic.
Wed Oct 07, 2015Post  #5
Prafulla sinha
Prafulla sinha
We have already done this at indrapuram. ghaziabad.
It was done in Feb 2015, no issue as yet.
Thu Oct 08, 2015Post  #6
Cool.
3223
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by Jemimmarichardson. Forum started by aammiitt
3425
I am planning to renovate my floor with vitried tiles. Contractor is suggesting
Last answer on 5/17/2017 3:00:33 PM. by S L Gupta (Civil Engg). Forum started by RKG
1884
Dear compatriots!Do you use glass mosaic tiles to enhance your housing experienc
Last answer on 5/5/2015 12:25:53 PM. Forum started by Keshav
2350
Need Suggestion
32662
Are there any problems in pasting tiles over an existing mosaic floor?
Last answer on 7/3/2020 10:21:35 PM. by Srinaath KS. Forum started by sunilbs9999
2085
Wood Textured Tiles
Last answer on 1/16/2015 11:37:30 AM. by John Son. Forum started by awdhesh
1930
1941
Last answer on 5/24/2012 5:08:53 PM. by S L Gupta (Civil Engg). Forum started by gaju
3121
1834
2234
paint
Last answer on 6/30/2021 1:46:52 AM. by S L Gupta (Civil Engg). Forum started by jollyjodhaka
2423
I am constructing first floor now. I want to know which flooring is better. Whet
Last answer on 4/17/2011 7:42:19 PM. by S L Gupta (Civil Engg). Forum started by S.BHUPAL RAJU
3076
3466
Kindly guide us for which type of flooring like marble, vitrified tiles is suita
Last answer on 4/12/2010 4:08:33 PM. by M Jindal. Forum started by Sanjay jain
2330
2620
Tiles
Last answer on 7/11/2020 8:08:42 PM. by freekundli. Forum started by Ahmed
2214
Tiles or Marble for Flooring
2212
floor tiles
Tile
Tiles
Tiles for Bathroom
Designing
Ideas for designing of floor tiles
Floor tile design ideas are many. Within the home or business area, ceramic tiles can be used to enhance and beautify a
Kitchen Backsplash
How to Install a Sink
Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s..
