How can we identify the First class brick. How it helps for the building strengt
Sat Apr 10, 2010
gk
Topic: How can we identify the First class brick. How it helps for the building strengt
How can we identify the First class brick. How it helps for the building strength.
The comment above talks about the image below.
Click on
the image to enlarge.
Wed Apr 14, 2010
Post subject: Reply-Identify brick and strength
Dear GK,
First class bricks are made from good earth which is free from saline deposits and are sand molded. You can identify the First class brick by following field tests and laboratory tests.
You can see the bricks should be burnt thoroughly without being vitrified and have deep red, cherry and copper color.
Bricks should have regular and uniform in shape and size with sharp and square edges and parallel faces.
Bricks should give a clear ringing sound on being struck together and are free from flaws, cracks, chops, stones and lime.
Laboratory tests:-
Bricks should not absorb water more than 20% of its own dry weight after 24 hours, immersion in cold water.
Bricks should have a minimum crushing strength of 105 kg per sq. cm when tested according to the specification.
Bricks should not show appreciable sign of efflorescence either in dry state or subsequent to soaking in water.
How it helps for the building strength?
First class bricks have more strength than second class and third class, as it is clear from minimum crushing strength of bricks i.e. First class bricks have minimum crushing strength 105 kg/ sq cm where as second class bricks have 70kg/ sq cm. First class bricks are fully brunt so there surface are more strong than second class bricks. For more information about bricks you can take help from the given below articles.
http://www.gharexpert.com/category/1395/Bricks-0.aspx?PL=2&Estimator=
S.L.Gupta
2866
Bricks
Last answer on 1/16/2013 11:34:07 AM. by
shahidain
3993
Last answer on 7/25/2013 5:11:37 PM. by
LAKWINDER
shahidain
2422
Last answer on 8/20/2015 2:23:19 AM. by
Gunjan
3147
i built one house so pls help me 27x42 sq feet
Last answer on 12/23/2011 5:00:58 PM. by
FARZAN
suryaprakash
2336
Last answer on 2/4/2015 11:35:37 AM. by
Arun
1412
sir please help me i want to build 3bhk in ground and first floor my plot area i
Last answer on 11/16/2016 10:37:54 AM. by
raghu
3802
22 x 63 size plot construction.
Last answer on 7/16/2015 10:39:22 PM. by
rajkumar pola
2042
It need to thinks for middle class people with innovative ideas to build such ty
Last answer on 12/12/2010 12:25:15 AM. Forum started by
S Borthakur
15361
2nd floor construction
Last answer on 7/3/2020 9:53:01 PM. by
bhuvaneshwaran bn
manjuks
2350
Vikas
2874
FLYASH OR CLAY BRICK
Last answer on 12/3/2013 11:46:22 AM. by
Abhishek
1620
Last answer on 10/5/2014 2:44:13 AM. Forum started by
tushar bhoj
2466
Last answer on 11/17/2015 8:51:17 PM. by
Techman
2196
Last answer on 1/5/2022 1:01:14 AM. by
Hardeep Jatrana
2202
Brick Masonry Columns
Last answer on 1/14/2014 12:50:59 PM. by
Ahmed
Ahmed
1570
Last answer on 7/4/2020 4:22:06 AM. by
Nisha Sapkal
2018
Last answer on 2/2/2022 11:26:31 PM. Forum started by
manjunath
2880
Bricks
Chandrasekaran S
1885
discussed about the estimate of of bricks in a wall in one square foot
Last answer on 5/20/2015 5:28:35 PM. by
bittushaikh
5812
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2866
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2374
Adriano Peres
vamsi
2463
nuksung
2638
dayal
1808
TUNDE
3608
ragha
6254
suba
Bricks Quality
Brick Arches
Orientation of Building
Specification of Brick
Buying tips for Bricks
