Home -> Forums -> Construction -> Plumbing -> can we lay bore water pipes over terrace?
Thu Apr 21, 2016Total posts : 1
jameel5
jameel5
Topic: can we lay bore water pipes over terrace?
we are constructing a new house in which bore water pipes has been laid over terrace before doing weathering course work.
is it right to lay water pipes over terrace before doing weathering course. I want to know whether it will damage the roof or any leakage of water occurs in future! please let me know the advantages and disadvantages!
Fri Apr 22, 2016Post  #1
      Cover the pipe in cement concrete before doing weathering course.
2894
Terrace water proofing
2196
is it possible to collect all rain water in terrace in the form of rcc duct and
Last answer on 6/2/2013 8:57:21 PM. by Navneet Jharia. Forum started by D.Ramachandran
1799
1826
1524
2730
terrace floor tile
Last answer on 9/14/2011 2:03:17 PM. by S L Gupta (Civil Engg). Forum started by nitin dahisaria
1843
Water dripping and Damp patches after laying sunban tiles(igloo tiles) in terrace
Last answer on 8/5/2015 4:24:08 AM. by JAI PRAKASH. Forum started by Radhika
1752
Dear Sir Constructing 72x43 East facing house.Pl guide me for water supply pipe
Last answer on 9/30/2015 8:59:54 PM. by JAI PRAKASH. Forum started by Sudhir Pathak
3804
cpvc pipes v,s gi pipes
2230
sewage pipes
2387
2418
1844
2766
1260
Is ground water from bore well suitable for construction?
Last answer on 9/9/2016 11:06:16 PM. by bhuvaneshwaran bn. Forum started by Sandeep
roofing on open terrace
2302
9174
2828
6270
Water Tank Quality
3114
Hot Water Tank
2914
Sand in Water
3380
Diverters for Bathroom
2561
2145
40516
2083
GI pipe Vs CPVC pipeline
2930
2079
Toilets
1987
Wall mounted cummod vs normal
5054
2775
2387
1854
3074
Swimming pool
2541
water softner
2681
commode type and flush type
4193
to shut off water to house
Roof Garden
General
Guideline for laying DPC
