Home -> Forums -> Construction -> Start Construction -> cement : sand:stone ratio
Sun Apr 05, 2015Total posts : 4
ananth
ananth
Topic: cement : sand:stone ratio
sir
what is the cement , sand and stone ratio for concrete for home.
Sun Apr 05, 2015Post  #1
For 4" wall it should be 4:1
For 9" wall it can be 6:1
For Lantel it can be 4:2:1 or 5:2:1
Mon Apr 06, 2015Post  #2
Dear Ananth
          Use Cement Concrete Ratio as 1;2;4 for small work and for column, beam and roof slab the mix ratio should be 1;1.5;3.
Wed Apr 08, 2015Post  #3
Cement      =1
Fine Sand  = 1.5
Stone         = 3
Thu Apr 09, 2015Post  #4
Dear Purvi
     Cement=1
Fine aggregate or coarse sand= 1.5
Bazri or coarse aggregate or stone chippings= 3
3791
1767
1460
4365
WHAT IS THE RATIO
3148
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
3591
1525
MIX PROPORTION
Last answer on 5/13/2016 10:51:18 AM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
4062
Forumula to calculate
Last answer on 7/3/2009 1:18:44 AM. by Priti Arora. Forum started by Anandan
3272
For Estimate
2691
Want to know the Strength of the Roof Slab
Last answer on 3/8/2011 5:41:21 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
1498
Could some one please provide sketch diagram of RCC Colums (pillars) e.g. depth
Last answer on 8/22/2015 11:24:20 AM. by S L Gupta (Civil Engg). Forum started by r.n.misra
2905
Cost of Cement Plaster
13756
2862
3494
1510
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
3615
Can we use crushed Sand for house construction
Last answer on 4/8/2014 12:28:09 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
16073
robo sand vs natural sand
3010
M-Sand for Plastering
3312
2236
2312
2061
Appropriate
Colors
Colors of Kota Stone
Kota Stone is a natural stone found in attractive, beautiful and eye soothing natural shades of greenish blue and brow..
Advantages
Concrete Mix Ratio
Garden
Garden Path Ideas
Italian
Italian Marble Flooring
