Home -> Forums -> Construction -> Steel -> chair in slab steel
chair in slab steel
Sat Apr 19, 2014Total posts : 4
shaik khaja nayab rasool
Topic: chair in slab steel
hai..sir       what is main purpose of chair in slab steel and what  is it's perfect dimensions as per code and its height,angle
Mon Apr 21, 2014Post  #1
Dear Rasool
      Your query is not clear.
Mon Apr 21, 2014Post  #2
in slab (steel) mat we use chairs near beam sides .what is its specifications as per IS code
Tue Apr 22, 2014Post  #3
Dear Rasool
         I think you want to know about supports / chairs laid under the crank bar. The cranks are given near beam or wall support. The height of chair depends on the thickness of slab. If slab thickness is 5'' than height of chair is 4''. The length of chair is from 18'' to 24''.
Wed Apr 23, 2014Post  #4
thank u sir
Steel-Construction Questions (39)
2843
Steel calculation
2890
3706
3096
5664
4807
2483
What will be coast of slab 5" for area of of 450Sq feet. I want material cost l
Last answer on 10/12/2014 9:25:00 PM. by SANJAY DUSANE. Forum started by milind
2664
Last answer on 7/2/2021 3:17:17 PM. by B Thakar. Forum started by minhaj sk
1980
Residential complex
1813
3157
postion of dental chair
Last answer on 11/18/2021 12:17:38 PM. by S L Gupta (Civil Engg). Forum started by manoj agrawal
2609
i only eant to know the direction of dental chair .head of patient andfeet
Last answer on 7/3/2020 9:17:23 PM. by S L Gupta (Civil Engg). Forum started by manoj agrawal
3369
plz tell me ideal position of dental chair n patient position in east facing den
Last answer on 7/3/2020 11:54:24 PM. Forum started by dr mona
2191
i want to buy these chairs where can i find them
Last answer on 5/9/2012 4:14:12 PM. Forum started by rama
2393
where i can get these chairs in chennai?
Last answer on 8/10/2017 1:27:41 AM. by S L Gupta (Civil Engg). Forum started by subramani
1777
Last answer on 4/13/2016 1:01:09 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1751
1573
How much steel required for 40*38 sq.ft Slab? how much material required.. cemen
Last answer on 1/5/2022 12:38:24 AM. by S L Gupta (Civil Engg). Forum started by Mani Kumar
1099
Last answer on 7/23/2018 11:32:12 PM. by S L Gupta (Civil Engg). Forum started by Mani Kumar
2668
steel requirment
15529
1980
Residential complex
4333
RCC Columns
3220
7435
Bar Bending Schedule Software
2508
steel
29811
2598
9334
2183
Current iron rod price
2593
1872
Steel Erectors
2364
3253
13637
overlap length to steel
2146
2524
How to choose a comfortable office chair
Selecting a good office chair is an important task to make your employees comfortable and more productive. Generally, ..
Living Room Chairs
Chairs draw everyone’s attention in drawing room as they are nice-looking and stylish articles of furniture. The selec..
Dining
Dining Chairs and Bar Stools
Type
Centering
