Home -> Forums -> Construction -> Brick work -> chamber brick or country brick ?
Wed May 10, 2017Total posts : 1
mknmohamed
mknmohamed
Topic: chamber brick or country brick ?
hi I will construct a residential house, I need a information which one is best for brick work chamber bricks or country bricks. and kindly give the advantages and disadvantages
Mon May 15, 2017Post  #1
     Chamber bricks are better and good in quality.
2992
2017
4179
GLASS BLOCKS / BRICKS
4056
2350
2873
FLYASH OR CLAY BRICK
2707
type of brick
3928
2025
2417
2865
Bricks
3992
2364
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Last answer on 7/9/2012 3:21:23 PM. by Ar. Manoj Ralen. Forum started by Lynda
7513
Brick Advice Urgent
3043
Last answer on 8/18/2011 6:51:51 PM. by prasadtvp. Forum started by chella earnest
8248
what are the disadvantages of flyash bricks?
Last answer on 12/31/2020 2:29:47 AM. by H S Rathi. Forum started by gganesan
6286
brick tile tracing
Last answer on 7/4/2020 2:14:39 AM. by S L Gupta (Civil Engg). Forum started by rahul
3433
35211
3669
wals
3262
compound wall
21875
3280
Bedroom Wardrobes information
2206
1494
1965
1732
2224
2523
1501
1909
Brick or ACC block
2025
1653
1702
4687
Brick wall on RCC slab
3928
2617
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
