What is the cheapest form of waterporoofing the terrace?
Fri May 02, 2008Total posts : 3
Vipul Hasija
Vipul Hasija
Topic: What is the cheapest form of waterporoofing the terrace?
Water proofing treatment is done on the top of roof is an important part of construction work. Any unnecessary saving or carelessness may cause dampness in the house. The cheapest form of water proofing on terrace is given below.
1) Apply 2 coats of bitumen on the top of RCC Slab after cleaning the slab with wire brush or brooms.
2) Lay mud plaster on bituminous surface.
3) Lay the earth in required thickness for making proper slope to drain rain water.
4) Lay brick tiles with mud mortar on earth work which was already laid in a proper slope.
5) Do cement mortar in the ratio 1:3 grouting on brick tiles and clean the surface with brooms.
6) Do curing for at least 7 days.
Sat Jun 07, 2008Post  #1
Tanya Batra
Tanya Batra
Post subject: Water Proofing the Terrace
Dampness causes several problems for the occupants of the building.
1. It affects the health of the person living in the building.
2. The building looks very ugly.
3. The cost of painting white washing is increased.
4. The life of the building is reduced.
Keeping in view above problems, water proofing of the terrace should be done according to the following methods.
1. Proper outlet for rainwater must be fixed.
2. Cement concrete Gola should be constructed at the junction of roof slab and parapet.
3. Proper slope should be given towards outlet for quick drainage of rainy water.
4. Two coats of bitumen should be laid on RCC slab.
5. The earth 3 inches to 4 inches should be laid on bitumen surface to make proper slope to drain rain water.
6. Tile tracing consisting of brick tiles should be laid on one inch mud mortar on compacted earth.
7. Cement pointing must be done on the joints of brick tiles laid in tile tracing.
Fri Jul 20, 2012Post  #2
sam_m400
sam_m400
Post subject: What is the cheapest form of waterporoofing the ...
What do you mean by earth as you stated "The earth 3 inches to 4 inches should be laid"?
Sat Jul 21, 2012Post  #3
Dear Sam
      The earth means ''Mitti'' from ground and this is laid for giving the slope to drain the rain water. This is laid nominal or zero at the mouth of pipe and maximum on the oter end to make slope.See the articles on the link for dampness.
http://www.gharexpert.com/category/1372/Dampness-0.aspx?PL=2&Estimator=
which is the cheapest type of flooring
Last answer on 4/4/2010 9:31:51 PM. by juhi. Forum started by Ankur
2634
tiles
1642
floor construction
5171
3910
2898
Terrace water proofing
1868
Precautions during Fabrication and Fixing of Window Grill.
Last answer on 9/5/2014 8:02:17 PM. by JAI PRAKASH. Forum started by subir
2066
Can u please tell me what should be the form and structure of a drawing room
Last answer on 9/19/2011 8:37:44 PM. Forum started by Ruchi Shrivastava
2639
where to keep pooja mandir in living room measuring 17X19sq feet with terrace in
Last answer on 3/24/2012 2:53:23 PM. Forum started by srpatil
3759
PLEASE TELL ME THE DIFFRENCE BETWEEN B.B.COBA AND IPS TYPE OF WATERPROOFING FOR
Last answer on 7/30/2014 9:22:58 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2298
3123
1544
Last answer on 1/28/2018 4:51:24 AM. by Er.S.K.Jain. Forum started by S.Nagarajan
1800
Shuttering Plywood
Last answer on 12/4/2011 6:16:40 PM. Forum started by Girish
2303
1645
Sr I wont to bild 600sq ft on piled house bicose my land is river front 8to10ft
Last answer on 10/11/2015 8:04:12 PM. by JAI PRAKASH. Forum started by ismail
22041
what is the full form of C.B. mentioned in the plan?
Last answer on 11/13/2014 6:29:10 PM. by JAI PRAKASH. Forum started by Navaz
1765
Window Size
Last answer on 2/21/2014 11:50:13 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
24
28
Roof Garden
Centering
What are the specifications for preparation of tiles for POP tiles ceiling?
Tiles of POP reinforced with hessain cloth are prepared in suitable sizes.The maximum size of the tiles is limited to ..
