Mon May 12, 2014 | Post #1 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear In construction of a house/ building house owner
should focus on electric works also; which need a lot of attention while
laying wiring as well as quality of wiring, specification of electric
appliances and cables/wires. Due to carelessness or lack of knowledge by
electrician fatal accidents may occur in later and take up more money
in repair. Thus every care should be taken while doing electrical
fittings. Here are given some tips on how to lay wiring.
Tue May 13, 2014 | Post #2 | Ahmed
Join date: Aug 2013 | Please ensure that not too many wires gets packed in a PVC pipe/channel.Because electric wires gets heated up and if they touch each other it vill be hazardous, Use certified cables, MCB, ELCB | |
Articles that might interest you! | | What is the checklist of cable lay out in home? Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident.. | | Checklists for flooring While going for any construction everyone needs some handy points on every stage of construction so as in while laying.. | | Checklists for Doors and Windows Doors and windows are costly item in house construction and it provides safety, ventilation and adds the beauty and lo.. | | Tips for Laying RCC slab / roof RCC slab laying is one of major step in any type of construction so it is mandatory to know all the points related to .. | | Checklist for Plumbing In construction of building or house like all other components, water supply is also very important part of building c.. | | Checklist for Cement Plaster In construction work plaster provides protection and decoration. Plaster work is important part of construction, which.. | | Guideline for laying DPC Damp proof course or DPC is a major process in construction. There are several guideline meant for DPC which are desc.. | | Electrical Fitting and Cable Wiring We all need power to run electrical appliances and different gadgets in our home. For proper distribution of electrici.. | | Guideline for labor for Ceramic or glazed tiles Flooring is important phase of any construction and if you are going for ceramic or glazed tiles flooring you must be .. | | Guideline for Labor laying stoneware or SW Pipes Do we know that there are several guidelines for labor to be followed while installing stoneware pipes? In the article.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
