Mon Aug 06, 2018 | Total posts : 2 |
| Topic: Which chokhat is best wood or iron press or aluminium
Which chokhat is best wood or iron press or aluminium |
Wed Aug 08, 2018 | Post #1 | Amit
Join date: Aug 2018 | Go for saal wood or neem wood. | |
Mon Aug 20, 2018 | Post #2 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Sir, See the comparison below
| Raw Material | Teak wood is a kind of hardwood and called the king of the woods. Usually the name of the teak in India is given based on the origin place of the teak. For example, if the teak wood comes from Burma then the teak would be called Burma teak and if it comes from Ivory Coast then the teak would be called Ivory teak. |
Implementation Raw Material | Teak is available in the market as Timber logs whereas some vendors are also selling custom frames that could directly be used in door and window frames. If you buy a log then you would need to cut the log into the required frame sizes and then let the door season. Seasoning is a process where you let the moisture in the wood dry to an optimal level. In normal dry warm weather, it is suggested that seasoning for about one month is recommended. After seasoning the timber logs, the logs are then used in the construction work as required. |
Style/Finishing | Teak wood is considered the best in furniture building. It gives desired finish and have smooth surface After the wood surface is polished, the wood looks very rich. Teak wood can be finished in the following finish: - Polishes.
- Painting.
- Varnishes
However, we recommend that if you buy teak then use it for the areas where you plan to do polish on the surface. If you want to use paint on the surface then you can use less expensive wood as well where the wood would be hard enough but would not have the required grains. |
Maintenance | - Teak wood is very strong and durable wood that’s why it only needs a little maintenance.
- Daily care such as cleaning the furniture with dry cloth can provide your teak furniture a long life.
- Re-polishing is recommended after a few years to bring back the shine in the furniture .
Advantages | - Teak is a kind of hardwood, popular for its durability and resistance to water.
- It provides a charming appearance and looks royal after finishing.
- Teak wood is easy to handle, polish and work with so a lot of carved designs are made using this.
- Teak wood is hard which makes it resistant to termite. Termites usually attack the wood that are softer in nature
Disadvantages | - The only disadvantage of teak wood is that it is comparatively expensive.
Uses | Teak wood is used in door and window frame, shutter and other architectural features. It is best option for furniture. |
Weight | Teak wood weight is from 700—800 kg/ cum. |
Hardness | Teak wood have elasticity and solid fiber, both of which facilitate woodworking and the ability of woodworkers to create products. |
Termite effect | It immune to white ant and insects attack for long period. How ever not always immune from fungus attack. |
Durability | Teak wood is out standing merit in retention of shape and durability. It is naturally durable wood. |
Color Range | Yellow to dark brown color. |
| Raw Material | Sal wood comes from Sal tree. Sal tree is straight and cylindrical and attains good length so you can longer lengths in Sal. Sal comes from Malaysia and other countries and is a little less expensive when compared to teak |
Implementation Raw Material | Sal wood is available in the market as Timber logs whereas some vendors are also selling custom frames that could directly be used in door and window frames. If you buy a log then you would need to cut the log into the required frame sizes and then let the door season. Seasoning is a process where you let the moisture in the wood dry to an optimal level. In normal dry warm weather, it is suggested that seasoning for about one month is recommended. After seasoning the timber logs, the logs are then used in the construction work as required. |
Style/Finishing | Sal wood is a rough construction wood. It is used for strength but not for finishing. Sal wood's surface have small cracks so they are finished with Paint or Oil but are not recommended for polishing. |
Maintenance | - Maintenance of Sal wood is easy as Sal wood is durable, termite resistance and remains free from fungi for a long time.
- Direct sun light on Sal wood should be avoided as it can result in cracks in the wood member.
- As the surface of the Sal wood is usually finished with paint, cleaning the wood would just require wiping with cloth.
Advantages | - 25 to 30% heavier and 45 to 50% harder and durable than teak wood.
- Resistant to termites, white ants and from fungi for a long period.
- Sal wood is durable and water resistant wood.
Disadvantages | - As Sal wood is very hard, it is not easy to saw and work with.
- This wood does not take Polish.
- Direct sunlight can cause cracks to Sal wood remember if you are planning for Sal wood flooring or furniture protect them form direct sunlight.
- Can not be used for exterior doors or furniture.
Uses | Sal wood is used for door and window frame, wooden beam, batten, piles and tool handle etc. It is not suitable for shutters and furniture. |
Weight | Sal wood is 30% heavier than teak wood i.e. its weight is from 900—1000 kg/ cum. |
Hardness | Sal wood is close grained hard and heavy. It is 50% harder than teak.
Termite effect | It immune to white ant and insects attack and fungus for long period. |
Durability | Sal wood is 20—30% stronger than teak. In shock resistance it is about 45% above teak. |
Color Range | Pale brown in color, darken on exposure. |
| Raw Material | Marindi wood is currently being imported from Malaysia. The tree usually grow to to a height of 45 meters and their stem is cylindrical shape.
Implementation Raw Material | Marindi wood is available in the market as Timber logs. If you buy a log then you would need to cut the log into the required frame sizes and then let the wood season. Seasoning is a process where you let the moisture in the wood dry to an optimal level. In normal dry warm weather, it is suggested that seasoning for about one month is recommended. After seasoning the timber logs, the logs are then used in the construction work as required. |
Style/Finishing | Marandi ( Mindi)wood have a smooth surface and can be finished using Paint, Polishing or Varnish |
Maintenance | - Marandi wood is also strong and durable wood that’s why it needs a little maintenance.
- Daily care such as wiping the furniture with cloth can provide your furniture a long life.
- Periodical painting and polishing is required as per the usage of the item
Advantages | - Marandi wood is a kind of hardwood, durable and resistance to water.
- It provides a charming appearance with high efficiency.
- Easy to handle, polish and work with.
- Polishing can make a good surface and is resistance to termite.
Disadvantages | Marindi is expensive than Sal wood. |
Uses | Marandi wood is used in door and window frame, shutter. |
Weight | Marandi wood weight range from 800- 900 kg/ cum. |
Hardness | It is closer grained, tough and durable. |
Durability | It is strong and durable wood. |
Color Range | Brownish grey color.
Questions (39) | |
1990 views | 2 answers | Last answer on 12/24/2015 4:18:32 AM. by JAI PRAKASH. Forum started by sushantsah | 2423 views | 1 answers | Last answer on 5/14/2014 1:56:15 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH | 2406 views | 0 answers | Last answer on 12/31/2020 2:40:39 AM. Forum started by Chacha |
| 2327 views | 1 answers | Last answer on 11/19/2013 1:31:03 PM. by Amit Hasija. Forum started by Toby Tyler | 1991 views | 3 answers | Last answer on 4/21/2015 11:30:50 AM. by S L Gupta (Civil Engg). Forum started by ashok | 6679 views | 1 answers | Last answer on 10/22/2020 10:47:11 PM. by Navneet Jharia. Forum started by gaurav | 2267 views | 1 answers | Last answer on 3/28/2012 5:11:30 PM. by Swati Satija. Forum started by sankari | 1933 views | 1 answers | Last answer on 4/6/2015 12:15:50 PM. by S L Gupta (Civil Engg). Forum started by archna | 2054 views | 1 answers | Last answer on 1/27/2015 7:34:42 PM. by JAI PRAKASH. Forum started by paresh | 1894 views | 3 answers | Last answer on 7/26/2015 4:39:53 AM. by Anuj Aggarwal. Forum started by Vishal | 5312 views | 3 answers | Last answer on 7/27/2013 7:55:03 PM. by Pooja. Forum started by GULSHAN RAI GULATI | 2254 views | 1 answers | Last answer on 7/4/2020 2:26:04 AM. by S L Gupta (Civil Engg). Forum started by Dhiraj Jain | 2892 views | 5 answers | Last answer on 5/28/2012 8:26:15 AM. by smithjames758. Forum started by Govind.s | 1470 views | 1 answers | Last answer on 10/20/2016 12:38:33 PM. by S L Gupta (Civil Engg). Forum started by Pankaj | 3451 views | 4 answers | Last answer on 8/20/2018 12:18:11 AM. by S L Gupta (Civil Engg). Forum started by kavitha | 2685 views | 1 answers | Last answer on 4/26/2021 10:00:27 AM. by mohamed. Forum started by Sanjeev Thakur | 2738 views | 0 answers | Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor | 2731 views | 2 answers | Last answer on 7/25/2013 5:15:06 PM. by LAKWINDER. Forum started by sunita | 3051 views | 2 answers | Last answer on 5/30/2013 11:04:45 AM. by S L Gupta (Civil Engg). Forum started by oscar | 7 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
Articles that might interest you! | | Bathroom Accessories Part-4 Accessories are functional devices used to make bathroom overwhelming.They provide great delight while taking bath bes.. | | Help you to Choose Best Material for your Garage Door Choosing a garage door requires consideration about material, finish and its appeal. Garage doors are available in dif.. | | Ready Made Doors Are you looking for appealing ready made doors for your home? Here is a variety of ready made doors to provide safety .. | | Garden Furniture Garden furniture makes your garden relaxing place to sit. You can choose from a wide range of furniture like benches, .. | | Reasons Why Aluminium Pipe Is The Best Choice When it comes to the heating, air conditioning and even plumbing systems in your home, you might be surprised to learn t | | Aluminum door advantages and disadvantages Aluminum doors are coming so fast in trend that you can notice them everywhere. The article will describe all the bene.. | | Aluminum door frame standard size There are various options of sizes in aluminum doors available in market. Choose the right one according to your purpo.. | | Cedar Wood For any construction wood is very major raw material and Cedar wood is one of most common type of wood to be used maki.. | | Wood Roof Shingles Wood roofing is probably one of the roofing materials you are considering. Warm and elegant look of wood roof makes it.. | | Hard wood Characteristics and application Hard wood is one of the major resources for wooden flooring today. You must know hard wood specification before buying.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
