Home -> Forums -> Construction -> Ground work -> cladding of tiles for sump tank
Tue Aug 31, 2010Total posts : 0
lakshminarayanaswamy
Topic: cladding of tiles for sump tank
is it good to put tiles for the sump tank on all sides.
only reason we are thinking is cleaning will be done easily.
please share your experiences and ideas.
5055
2990
details about wall claddings, tiles & all including its rate
Last answer on 10/8/2020 12:45:36 AM. by S L Gupta (Civil Engg). Forum started by laxmi
13537
1520
Looking or help on designing the front portion of the house. It can be tiles or
Last answer on 9/22/2017 12:01:52 AM. by S L Gupta (Civil Engg). Forum started by SVasan
2685
Last answer on 4/26/2021 10:00:27 AM. by mohamed. Forum started by Sanjeev Thakur
1958
2043
Underground Water storage
2073
Weight on Sump Tank
Last answer on 2/3/2021 11:35:35 PM. by JAI PRAKASH. Forum started by awdhesh
2444
Underground sump finished with granite/tiles
Last answer on 12/26/2014 2:16:16 PM. Forum started by am.sridhara
2196
Last answer on 12/31/2020 8:58:35 PM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
2101
2219
2149
2662
sir want the detail specification of acp cladding , such as thicknesss of sheet,
Last answer on 1/17/2013 12:27:08 PM. Forum started by somashekhar
10066
cost estimation of water storage sump tank
Last answer on 9/26/2010 5:48:55 PM. by sathish. Forum started by manjuks
2756
Construct a sump / basement water tank in drawing / living room
Last answer on 7/5/2011 4:18:52 PM. Forum started by kamalesh
4722
Cost estimation for sump tank
5733
4384
Last answer on 7/4/2020 2:05:07 AM. Forum started by NV MANI
2995
8159
software
3899
2730
1833
lanterns
3133
false ceiling
2245
about construction
1786
4153
Cement Coba
3076
Water Harvesting System
1676
1758
water tank
2058
1760
1634
Pool construction cost
1994
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
Vastu for Water Tank
Preventive
Reasons of dampness
Tile
Tiles
Tiles for Bathroom
Designing
