Home -> Forums -> Construction -> Cement Plastering -> coarse aggregate
coarse aggregate
Fri Jul 31, 2015Total posts : 3
satinder parshad
satinder parshad
Topic: coarse aggregate
how to test the quality of coarse sand and fine sand on site
Mon Aug 03, 2015Post  #1
      The fineness of fine and coarse sand can be determined by using  sheaves for silt are below.
  • To check the quality of fine aggregates or sand; put some quantity of sand in a glass of water. Then it is vigorously shaken and allowed to settle. If the clay is present in sand, its distinct layer is formed at the top of sand.
  • To detect the presence of organic impurities in sand, a solution of sodium hydroxide or caustic soda is added to sand and stirred. If the color of solution changes into brown, it shows presence of impurities
Wed Aug 05, 2015Post  #2
Wow.
Mon Aug 10, 2015Post  #3
satinder parshad
satinder parshad
thanks sir
1850
Last answer on 7/11/2011 12:00:45 PM. by S L Gupta (Civil Engg). Forum started by KALPANA
1607
Specification of Coarse Aggregate
Last answer on 1/23/2013 1:02:12 PM. by S L Gupta (Civil Engg). Forum started by S P Singh
2245
about construction
2327
Roof flooring
3494
2718
1553
Last answer on 6/7/2017 12:20:58 PM. by S L Gupta (Civil Engg). Forum started by Sandeep Vidwans
3866
1670
1783
What is aggregate
Last answer on 4/3/2014 11:18:54 AM. by S L Gupta (Civil Engg). Forum started by raza abbas
3841
3386
1497
Could some one please provide sketch diagram of RCC Colums (pillars) e.g. depth
Last answer on 8/22/2015 11:24:20 AM. by S L Gupta (Civil Engg). Forum started by r.n.misra
2259
m15 cost vs m20 cost
1524
MIX PROPORTION
Last answer on 5/13/2016 10:51:18 AM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1448
QUANTITY MEASUREMENT
Last answer on 1/21/2022 12:55:08 AM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1240
how much it cost for total 66 sqmt RCC, the area include roof 45.12 m3, coulmn 5
Last answer on 12/26/2016 12:38:13 PM. by S L Gupta (Civil Engg). Forum started by ahmed
3588
Per Sq:ft rate for flooring
4240
mix design of rcc slab
Last answer on 7/31/2012 11:18:03 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
2929
Plaster
2780
Plaster work
3046
Plastering
1925
2003
PPC and OPC cement
11298
1870
suggest for exterior
7004
9157
1876
OPC and PPC cement
2157
1826
Nice
2436
Gypsum Plaster Vs S/C Plaster
2173
Outer Plaster
2996
2734
putty work on walls
2236
2826
2033
Density of Coarse Aggregate
Coarse Aggregate consists of crushed, uncrushed or broken stones. Check the grading of sand for proper sizes.
What is aggregate
There are mainly two types of aggregate:Fine aggregate and coarse aggregate. Let us know more about aggeregate in foll..
Aggregates of concrete and their density
In cement concrete aggregates occupy 75-80 percent volume of concrete, so you can say Aggregate is a major resource fo..
Cement
Cement Concrete
