Home -> Forums -> Construction -> Basement -> column STRUCTURE
column STRUCTURE
Fri Nov 06, 2015Total posts : 2
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Topic: column STRUCTURE
What MM size & what type of structure would be is required for 1650 square foot roof of 3 storied building.
Fri Nov 06, 2015Post  #1
It depends upon the requirement at different places in the building.
Column should be in atleast 16 mm. Lantel 12mm. RCC Shelf 8 mm or 10 mm.
Mon Nov 09, 2015Post  #2
Dear Mondal
      Design is depends upon the load bear by column. Plan of building is necessary fo design.
2616
COLUMN nd LOAD BEARING
1846
Column structure...
Last answer on 5/3/2016 12:12:02 AM. by JAI PRAKASH. Forum started by R SURYAPRAKASHA
2037
construction of second 7 third floor
Last answer on 1/2/2013 11:45:31 AM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1643
planning to construct a single storey house very close to the sea
Last answer on 6/16/2014 11:07:07 AM. by S L Gupta (Civil Engg). Forum started by nkumar
2749
1764
2132
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by S L Gupta (Civil Engg). Forum started by Syed Shahed
2330
65238
3091
Last answer on 7/26/2009 8:35:08 PM. by Ganesh. Forum started by cosntruction novice
2142
About column and beam structure
Last answer on 1/4/2019 11:39:23 PM. by S L Gupta (Civil Engg). Forum started by Rana kachari
1897
Structural design
Last answer on 7/3/2020 10:29:46 PM. by S L Gupta (Civil Engg). Forum started by Akhil George
2298
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
2115
Structure proof checking
2210
3017
6440
Column placement for house
4939
COLUMN AND STEEL DESIGN
4939
9061
makan map
2774
17223
1993
2157
design of column
2282
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2797
1970
ffff
1872
4211
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
Earthquake
Termite Control
Through
Various
