Home -> Forums -> Construction -> Start Construction -> column, slab, beam,
column, slab, beam,
Sat Sep 03, 2016Total posts : 1
deepak
deepak
Topic: column, slab, beam,
sir mere plot ki size 13'x30' he me is plot par multistory bulding banana
chatah hu kya app mujhe bta sakte he ki mujhe apne plot ke hisab se
colounm,slab, beam me kitne mm ki steel bar use karni chiye
Sat Sep 03, 2016Post  #1
Dear Deepak
           The design of R C C columns,  footing, beams and slab is designed according to load bear by them taking factor of safety from earth quack, bearing capacity of soil Span of column, length of beam etc in consideration. For basement and other 5 floors or  stories it is better to take design from structural engineer. When you are spending billion of rupees than do not take risk for design to spent a nominal expenditure. design can save your money at long run and a tentative design we offenly  use more steel than require and some time it is dangerous..
2557
1366
10048
3623
2719
2702
4010
labor rate for RCC work
3721
3303
2650
Cost of construction of roof slab.
Last answer on 9/13/2013 11:42:05 AM. by feroz khan patthan. Forum started by suhas
13772
overlap length to steel
2783
2036
2707
2302
2033
3310
Centering
Dining
Dining Room Ceiling
Reasons of dampness
