comments required
comments required
Tue Aug 07, 2012
gangula
Topic: comments required
For this plan i need vastu commnts and Other comments.
if possible one excel sheet of Building Cost (Bill of materials take off - for cost estimation)
gangulamr@gmail.com
5.8c.pdf on Tue Aug 07, 2012,&n
Tue Aug 14, 2012
Post subject: GharExpert can provide estimate in excel
We will be requiring the drawings of floor plans, structural drawings, sections and if possible elevation design.
From the drawings we will get the area, walls, thickness, etc.
2620
Tiles
Last answer on 7/11/2020 8:08:42 PM. by
freekundli
Ahmed
3707
need comments on the plan subm,itted by sudha
Last answer on 11/18/2021 10:00:26 AM. by
zenithfilmsg
sudha
2644
Comments on Floor plan
Last answer on 12/8/2021 9:39:29 PM. by
Amir Rehman
2466
Last answer on 6/24/2013 3:10:11 PM. by
kk
2680
My House design
Last answer on 12/4/2013 12:34:48 PM. by
Manikandan
Manikandan
2211
Last answer on 12/14/2010 7:35:48 PM. Forum started by
Rakshit
1940
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
1597
How much Marole required
Last answer on 7/3/2020 11:26:58 PM. by
Yousuf
2014
required plan for 15/40 site 2bhk with vastu
Last answer on 1/23/2022 3:38:51 AM. by
mangala
2865
Steel calculation
Vamshidharreddy
30 X 50 EAST FACING REQUIRE PLAN WITHGROUND + 3 FLOORS
Last answer on 7/1/2016 12:51:14 PM. Forum started by
Dr.Vijayakumar gampa
2419
20*52 plot consruction house plan material estimite required
Last answer on 7/4/2020 2:11:15 AM. by
sanjay mishra
721
Last answer on 9/19/2020 12:24:32 AM. Forum started by
Rohit Kumar
2058
how much green paint required in 1sqm
Last answer on 7/8/2011 8:24:30 AM. by
Abrar Ullah
sherab tenzin
2321
Last answer on 4/13/2011 6:59:26 AM. by
rammohandas
2445
Last answer on 8/6/2011 2:32:51 PM. by
nita
3041
Last answer on 8/18/2011 6:51:51 PM. by
prasadtvp
chella earnest
3166
Last answer on 12/31/2020 2:11:59 AM. by
Ashok Negi
VILAYATWALA ALIASGAR ABBASI
2549
Tips for Varnish
Last answer on 3/17/2010 12:38:44 AM. by
vinay meghani
Which are various types of vinyl flooring?
Two types of vinyl flooring such as inlaid and printed............
