Home -> Forums -> Construction -> Brick work -> compound wall
compound wall
Tue Jan 27, 2015Total posts : 1
Satish Pingulkar
Satish Pingulkar
Topic: compound wall
EATIMATE.
A) PLAIN COMPOUND WALL –  62’ X 5’ = 310 SQ.FT
B) BRICK WORK( 2’)+ CHAIN LINK (3’)=43’9” X 5’ = 218.75 SQ.FT
C) GATE REMOVING AND AGAIN FITTING
A) ABOVE ESTIMATE INCLUDING ,BED PCC 3”, UCR WORK-1’6” X 1’6”, PLINTH COPING- 4”(PCC),BRICK WORK 9”-5’ AND 2’(CHAINLINK), TOP COPING 3”, INTERNAL AND EXTERNAL SINGLE COAT 12MM THK.PLASTER.CHAINLINK IN ANGEL FRAME 35X5 AND CHAINLINK 12G-45X45 POCKETS.
B) TAKING ONE COAT WHITE CEMENT PRIMERTO WALL AND ONE COAT BLACK OIL PAINT TO CHAINLINK ANGEL FRAME.
What would be the approx estimate for this compound wall?
Tue Jan 27, 2015Post  #1
80-90k
5554
1815
1502
1703
858
5864
Estimation
3118
concrete brick or clay brick
3645
Compound Wall
3862
Compound Wall Construction
2836
13651
2398
6254
2069
Last answer on 9/16/2014 11:09:41 PM. by bijumohang. Forum started by bijumohang
4544
Construction of Compound wall
Last answer on 8/4/2011 1:22:22 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
4974
Cost estimate for raising compound wall and shops
Last answer on 1/6/2012 2:32:27 AM. by ravi at Dalmia. Forum started by mrakesh
2769
Compound wall construction
Last answer on 11/5/2014 9:02:10 PM. by SANJAY DUSANE. Forum started by Mahesh
1686
Compound Wall
Last answer on 11/7/2013 1:12:44 PM. by Abhishek. Forum started by Abhishek
5655
Last answer on 12/17/2020 5:53:41 AM. by shamsmehra90. Forum started by Nirmala Rangarajan
3669
wals
21875
3280
Bedroom Wardrobes information
2246
2206
1494
1965
1732
2224
2523
1502
1910
Brick or ACC block
2025
1653
1702
4687
Brick wall on RCC slab
3928
2617
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
Beyond
Wall
Wall painting design
