Home -> Forums -> Construction -> Layout and House Plans -> concrete beam
concrete beam
Fri Sep 23, 2011Total posts : 1
daniel
daniel
Topic: concrete beam
hi friends
I am confused about the concrete beams and columns
I am going to put columns on my plan which i designed
1. is it true that wherever we have a staircase we have two beams parallel to it?
2. if I have two 300*300  columns what is the maximum span between the two
and what about the 150*200 columns?
thx alot
Mon Sep 26, 2011Post  #1
Dear Daniel
     The contents send by you is not understandable without proper plan. The plan should be marked the beams columns for which you want quarry.
6356
3272
Roof Concrete Strength
9195
6880
4010
labor rate for RCC work
4664
Regarding Beam
3656
1311
1767
1460
1978
2054
3303
3837
Roof Beam
2331
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
4764
Last answer on 8/27/2012 4:35:27 PM. by Amit Hasija. Forum started by prakash
12251
3470
Cost of concrete walls
1899
Offset between Concrete Slab and Wall
Last answer on 12/4/2014 1:02:25 AM. by JAI PRAKASH. Forum started by Harinath P
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Centering
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Dining
Dining Room Ceiling
