Home -> Forums -> Construction -> Bricks -> concrete brick or clay brick
Mon Sep 03, 2012Total posts : 2
pallubc2
pallubc2
Topic: concrete brick or clay brick
Hello All,
Which type of brick would be economical and strong to build compound wall.
Pallavi
Tue Sep 04, 2012Post  #1
Post subject: Concrete bricks are strong than clay bricks
Dear Pallubc2,
Concrete bricks are made of cement, sand and aggregate so it become strong and costly where clay bricks are made with natural clay so it is low in cost and strength.
So cost wise clay bricks are good where strength wise I would prefer concrete bricks.
Thu Sep 06, 2012Post  #2
pallubc2
pallubc2
Thanks for your suggestion.
2992
1797
1341
2025
2874
FLYASH OR CLAY BRICK
6450
3433
1863
Last answer on 1/5/2022 9:14:05 PM. by sanjay agarwal. Forum started by saradha
7513
Brick Advice Urgent
9196
3457
3081
1067
837
My house is made of clay and bricks of wall 15 inch in 960sqft but the roof has
Last answer on 7/4/2020 3:55:06 AM. by S L Gupta (Civil Engg). Forum started by Raj
2523
5135
Use of Solid Concrete Bricks
2018
1728
Last answer on 11/6/2015 12:41:03 AM. by JAI PRAKASH. Forum started by Techman
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2822
2350
3172
bricks
5660
2014
3238
5135
1625
1341
1846
1480
1797
2967
fly ash bricks
2230
1724
Various Types of Bricks
Brick Arches
Specification of Brick
Concrete Mix Ratio
Bricks Quality
Brick Pillar
Buying tips for Bricks
