Foundation
concrete filling
concrete filling
Thu Apr 17, 2014
shaik khaja nayab rasool
Topic: concrete filling
hai..sir why should we won't fill the trench or any earth filling with broken concrete pieces
Fri Apr 18, 2014
Dear Rasool
If we fill broken concrete in filling under floor or in any trench than there is possibility of voids and there will no proper compaction which leads to settlement in flooring after some time.
Fri Apr 18, 2014
thank u sir
2535
RCC column (pillar)
Last answer on 7/3/2020 11:20:24 PM. by
bibhas naik
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
1392
Last answer on 12/9/2020 11:08:46 PM. by
1762
vishal Thakur
1456
vishal Thakur
3469
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
1912
foundation type confusion : pls suggest
Last answer on 12/18/2015 11:22:33 AM. by
sushantsah
20122
Last answer on 2/18/2022 6:35:57 PM. by
SusanBones
mani
2222
zero slump concrete
Malik Usman
1785
Last answer on 3/1/2015 8:08:06 PM. by
2276
swarup chakraborty
2414
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
2413
Last answer on 10/12/2014 8:50:05 PM. by
sakthi
1618
Last answer on 10/5/2014 2:44:13 AM. Forum started by
tushar bhoj
3275
Last answer on 10/12/2014 9:03:20 PM. by
rajeev
3767
Last answer on 7/4/2020 2:12:02 AM. by
Priti Arora
farid
3767
concrete mix design software
Last answer on 1/21/2021 9:34:10 AM. Forum started by
Robin
2241
sand alternate for concrete
Last answer on 10/9/2010 11:37:42 AM. by
G N Shaikh
manohar
2683
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2140
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2371
structure work
mamtagarg
manish agarwal
5166
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2202
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2821
building a house
nashir
1990
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3089
Foundation
kamal
2272
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1476
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
10046
manishkumar
manishkumar
3660
Foundation
Rohit Sharma
2115
Structure proof checking
Arnab Ghosh
2558
Foundation design
DavidFlores18
nithun
2459
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2467
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3655
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2676
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
3179
satya
13266
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Earth Filling
Concrete Decor
Concrete Mix Ratio
Ready Mix Concrete
