Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> concrete grade
concrete grade
Tue Dec 22, 2015Total posts : 4
Rohit Sharma
Rohit Sharma
Topic: concrete grade
I have house plan for 22.5* 40.  Max room size is 11*11. All room corners has columns.  My mistri has 30 years of onsite experience in residential construction.  I told him to use m15 in column footing and m20 in columns above plinth level. He said for above mentioned grades we need vibrator and concrete mixer which is not economical option for smaller plots having maximum span less than 16 feet. He told me to use 1:2.5:4 through out the columns upto 2 storey building as we needed to mix concrete by hand and if bajri is more then concrete will not get smooth.
    1:2.5:4, or 1:3:3 or 1:3:4 is prevailing commonly in our area when I asked some other mistris.
He will be using mixer and vibrator for rcc slab only
What to do sir?
Tue Dec 22, 2015Post  #1
Dear Sharma
            Use cement concrete in the column 1;1.5;3 If any problem than with this ratio add extra small quantity of coarse sand nothing else.Do proper mixing by hand mix and vibrate by roding with steel bars or bamboo.
Wed Dec 23, 2015Post  #2
Rohit Sharma
Rohit Sharma
Thank you sooooooooooo much,
1 more question. Sorry for the inconvenience caused. How much reinforcement is needed in stairs? i'm not constructing beam stairs
Wed Dec 23, 2015Post  #3
Dear Sharma
     The MS Steel bars are according to design stair taking load. However lay 12mm MS Steel bars @ 4'' c/c with cement concrete ratio 1:1.5:3with proper mixing.
Thu Dec 24, 2015Post  #4
You are going good.
11587
3079
Dear Sir,What is the concrete grade used(M15/M20 etc.) in roof casting of normal
Last answer on 12/9/2021 10:16:53 PM. by S L Gupta (Civil Engg). Forum started by pal
2319
cement
Last answer on 8/25/2012 12:33:40 AM. by Ar. Manoj Ralen. Forum started by abhijeet joshi
1742
1785
grade of concrete
Last answer on 8/5/2014 8:44:47 PM. by JAI PRAKASH. Forum started by chethan
1403
6619
Last answer on 1/7/2022 1:25:49 AM. by Girish. Forum started by Girish
1767
1460
1765
Stair Grade Beam
Last answer on 3/30/2017 12:59:46 PM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen
2693
302 vs 304 grade steel for ralling
Last answer on 3/20/2015 9:55:35 PM. by JAI PRAKASH. Forum started by paresh
1755
biggest confusion
Last answer on 12/29/2015 12:52:15 AM. by JAI PRAKASH. Forum started by sushantsah
3443
Type of Cement
2697
3470
Cost of concrete walls
20129
2116
2223
zero slump concrete
1786
5812
3793
9886
2670
4628
4143
2868
5009
3658
1865
2801
2610
2374
2464
2638
1809
3608
6254
Concrete Decor
Concrete Mix Ratio
Types of Cement
Ready
Ready Mix Concrete
