Home -> Forums -> Construction -> Start Construction -> construcion of a new house
Wed Feb 12, 2014Total posts : 1
pmlaks
pmlaks
Topic: construcion of a new house
I am planning to build a house at 1200 sq (20 * 60)
I want to have a prope skech for the same.
The plan should be
Ground floor  - 1 BHK (600/700 SQ.FT)
FIRST FLOOR   1000/1100 sq ft   2BHK
Second floor (1 hall with attached bath room inner connected from  I floor)
Can anyone help on this Or how much wil you charge for the plan
Lakshman
Tue Feb 18, 2014Post  #1
2400
i m start new house
Last answer on 5/17/2021 2:35:58 PM. by David80Dyson. Forum started by king jain
2323
so pls sugest eme start new house acc to vastu shastra
Last answer on 12/30/2010 9:09:03 PM. by S L Gupta (Civil Engg). Forum started by king jain
4073
2413
I want to see new houses exeterior image&living room
Last answer on 7/3/2020 10:57:28 PM. by S L Gupta (Civil Engg). Forum started by rakesh13
2447
1921
Last answer on 9/17/2014 10:56:01 PM. by JAI PRAKASH. Forum started by somasekhar
2309
New Home
2321
depth of footing
Last answer on 1/13/2014 2:32:16 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2022
2962
4263
860sqft construction
Last answer on 10/12/2015 6:35:12 PM. by Rahul. Forum started by Shivaprasad
2725
My new plot is west facing,And apartfrom west side gate,which is the best direct
Last answer on 5/31/2012 5:39:05 PM. by Sumsn Kumar Mohanty. Forum started by lakshmana Chari
3940
modular kitchen
Last answer on 4/9/2013 1:56:21 PM. by mike hussey. Forum started by kcantony
1878
in as house well was in SW..but a new BORE was taken in NE..will this compensate
Last answer on 3/25/2011 12:53:49 AM. by sabina vanjani. Forum started by D.Ramachandran
5956
new construction in 300 sq yards place ...planning
Last answer on 2/20/2011 12:22:40 PM. by Gunjan Utraja. Forum started by vihal madishetty
2304
i want to set this type picture in my new house so i want detail about this pict
Last answer on 8/17/2010 7:38:11 PM. by ashu jain. Forum started by sathya
2647
2869
Last answer on 12/31/2020 1:54:01 AM. by prasad. Forum started by kalpana sharma
2107
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
3296
3309
2133
2059
Happy
Happy New Year 2009
Happy
Painting
Environmentally
