Home -> Forums -> Construction -> Start Construction -> construction/architecture
Fri Feb 21, 2014Total posts : 2
pranab samanta
pranab samanta
Topic: construction/architecture
I have a plot 36'*35' ,want to make a home ground flore and first flore construction. ground flore for 2* 1bhk flat for rent and first flore for self use contain 3bhk flat please give me sutablearchitect plan....
Sat Feb 22, 2014Post  #1
Post subject: Construction on plot 36' X 35' ,
Dear Pranab...Hello..! A good planning is required for your dream house..for planning kindly send some more informations about the plot and its surroundings like 1. direction of plot 2. Front road width 3.construction  or roads on all three sides. 4. Your requirements (Already attached)  . regards..
Mon Feb 24, 2014Post  #2
Dear Pranab
1950
what style of architecture is this
Last answer on 7/28/2015 11:32:45 PM. by JAI PRAKASH. Forum started by Wulfy Albert
1889
I have a piece of land 25'width/50'length.Pls. suggest me for home making archit
Last answer on 2/19/2019 11:23:49 PM. by Saurav anand. Forum started by ashish panchal
1990
architecture structure for construction of a 4 storey house on the vacnt plot me
Last answer on 11/10/2016 5:25:15 PM. by rajesh. Forum started by S.S.Dewangan
2841
hey hi im an architecture student n i gt a prjct f dsgning a dance institute.so
Last answer on 7/3/2020 11:54:53 PM. Forum started by akshatha.b.raj
4744
im an architecture student. quesrion: what are the requirements of designing a s
Last answer on 7/3/2020 10:32:27 PM. by S L Gupta (Civil Engg). Forum started by meremiya
3944
Architect's cost
Last answer on 9/22/2020 10:16:36 PM. by Cherryni. Forum started by Ajay Kostha
1571
I want more information regarding architecture design, working design & ground f
Last answer on 4/22/2021 11:03:06 PM. Forum started by Srinivas
1667
Last answer on 10/5/2016 8:18:52 PM. by Srinivas. Forum started by Srinivas
1743
i want a good architecture of a Bungalow of area 950 sq.ft or 19x50sq.ft.
Last answer on 1/20/2015 12:17:53 PM. by seema tyagi. Forum started by Shubham
1745
Yes,I want more information regarding architecture design, working design & grou
Last answer on 8/26/2020 3:09:30 AM. by JAI PRAKASH. Forum started by prakash thakur
2016
Basement Construcyion
Last answer on 6/16/2011 7:38:32 PM. Forum started by Pragalbh
4383
Home Architecture
Last answer on 11/16/2021 7:51:10 AM. by Abhi Kumar. Forum started by Ar. Manoj Ralen
2546
vastu, architecture and engineering.
Last answer on 8/8/2010 12:56:44 PM. by Anil Kumar Mishra. Forum started by Anil Kumar Mishra
3492
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
3089
2019
2299
1871
1783
3309
2133
2059
Apron Definition
Apron is A decorated or plain strip of wooden strip Flat strip placed under window stool It is the lower p
Arcade (Architecture)
what is an arcade? Read the article to know more about it.
