Home -> Forums -> Construction -> Start Construction -> construction cost for a 2bedroom house
Fri Oct 22, 2010Total posts : 5
kiran
kiran
Topic: construction cost for a 2bedroom house
I am planing to construct 2bed room house in 130 Sq. yards, how much it is going to cost me? Please let me know asap.
Kiran
Fri Oct 22, 2010Post  #1
Post subject: Please send the details
Dear Kiran,
Thank you for contacting GharExpert for Detailed cost estimate
The detailed cost estimate pricing is:
Up to 2000 sq.ft area= Rs.3.00 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.50 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.2.00 per sq.ft.
Above 10000 sq.ft area= Rs.1.50 per sq.ft.
We will take almost 12 business days to prepare the detailed cost estimate.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
For preparing the detailed cost estimate, We need additional documents from you:
1. Please, supply the elevation and section if any.
2. What type of flooring are you planning to use in all the rooms?
3. What is the size of Doors and Windows?
4. How much is the height of Ceiling?
4. Which type of frames is being used for doors and windows?
5. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. What material are you planning to use on Bathroom and Kitchen Walls?
8. What type of finishing will be used for Exterior walls?
9. Please, supply the Architectural drawings.
GharExpert can provide you a detailed cost analysis for your project that will help you save a lot of money.
A sample file for the estimate is available below.
http://www.gharexpert.com/include/sample_estimate.pdf .
Also send me the required documents and information to support@gharexpert.com so that we can start preparing the estimate.
Please let me know if you have a question.
Gunjan
09354908601
Sat Oct 23, 2010Post  #2
HKP
HKP
Post subject: Detail engg. Drawing and estimation
i am planning to construct duplex of 1100 (gf) and 500 (ff) and want for detail drawing, elevation, cost estmation.
please guide me
H K Pandey, Panipat Haryana
Sat Oct 23, 2010Post  #3
Venkataswamy Chinthalapudi
Post subject: Cost for self construction with labour contract.
For medium range good quality self construction at present raised costs of labour and materials.
Tier-1 cities / Metros - Rs. 1100 - 1300/Sqft
Tier-2/Muncipalities - Rs. 900 - 1200/Sqft
Tier-3/Towns - Rs. 750 - 1000/Sqft
You may split above costs as 60% material , 30% labour (on contract basis) and 10% other expenses approximately.  Please note that if you use daily labour, it costs you 5% to 10% more.
Venkat.
Mon Oct 25, 2010Post  #4
shikhar goel
shikhar goel
Post subject: hello kiran
hello kiran
if u r going to create a house in 130 sq feet
than if u want the medium ranges then the estimate will be as follows:
total cost including construction of building including:
cement
bricks
rcc
pipe fitting
wiring
doors of plywood
primer on walls
pop(130 rs running feet in the case of false ceiling)(normal pop around 60-70rs)
architect charges(12-15 rs per sqfeet)(visit charges will be around 1000rs per visit)
railings (1200-1600 rs per sq.feet ss 204)
grills(depends on the rate of rcc around 52-55 rs per kg)
main gate(around 15000)(standard gate)
so u must undergo an estimate of around (700-750 rs per sq.feet for a medium home)
(390*750)=1000000lac rs minimum required for an avg home
3137
i want some samples house map 25X45(2bedroom,kitchen,drawing room)please send me
Last answer on 7/20/2015 12:01:25 PM. by seema tyagi. Forum started by mulchand
1702
1421
i needs urgently 10*49 sq ft,housh plan, for 2bedroom 1 hall 2 bath
Last answer on 2/23/2017 11:21:28 AM. by S L Gupta (Civil Engg). Forum started by anshul
2592
MY PLOT IS 31*40 KINDLY SEDD ME 2BEDROOM SET
Last answer on 1/23/2012 11:05:41 AM. by S L Gupta (Civil Engg). Forum started by SJPS.SINGH
1784
6099
What is construction cost
2593
JOINERY WORKS
2489
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
8582
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
1994
Sir I WANT TO KNOW THAT HOW MUCH CONSTRUCTION COST OF THIS HOUSE WILL BE EXCEPT
Last answer on 7/17/2013 11:42:13 AM. by S L Gupta (Civil Engg). Forum started by mahesh
1676
if we plan marbal/Tiles work later on after 2/3 year of construction of house i
Last answer on 7/31/2014 7:48:23 PM. by JAI PRAKASH. Forum started by dspatwal
3597
2354
what would be the cost of construction for this kind of house for approx floor o
Last answer on 8/21/2010 12:50:17 PM. by S L Gupta (Civil Engg). Forum started by bhavin
4647
2976
10179
1977
Supervision cost
3312
2312
Why
