Home -> Forums -> Construction -> Basement -> construction cost of apartment
Wed Apr 10, 2013Total posts : 1
suresh
suresh
Topic: construction cost of apartment
Sir,, i want to construct the new apartment in 472 sqyds. ground, 1,2,3 floors, kindly give me the details how much cost for this construction including power, lift and generator.
Thu Apr 11, 2013Post  #1
Dear Suresh
1.         The cost of construction is based on the plan ,elevation and specification used in the construction of building. For example the cost of basement is very less than ground, cost is also co related with types of foundation. For accurate costing you can e-mail at support@gharexpert.com for detail estimate.See the link below.
6099
What is construction cost
2783
2353
6464
4807
2680
3384
what will be construction cost for a bunglaw at khandala, near lonavala
Last answer on 4/27/2016 3:10:29 PM. by S L Gupta (Civil Engg). Forum started by vaid
10177
1977
Supervision cost
2535
1476
2745
1783
23866
2266
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
3045
Which would be a better options for apartments (medium and high rise) Concrete Tanks or Sintex Water tanks
Last answer on 10/20/2010 3:34:11 PM. by . Forum started by savietha
5044
How to calculate Built Up Area to Carpet Area
Last answer on 7/3/2020 9:39:12 PM. by S L Gupta (Civil Engg). Forum started by ANIL SHAH
1915
construction cost
Last answer on 1/31/2022 4:30:31 AM. Forum started by Roogwed adep
9061
makan map
2774
17223
1993
2156
design of column
2281
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2796
1970
ffff
1872
4209
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
