Thu Dec 22, 2016Total posts : 1
sathis
sathis
Topic: the construction cost range 1200 to 1400 per sq-ft.above the cost are including
the construction cost range 1200 to 1400 per sq-ft.above the cost are including eletrical works or excluding
Fri Dec 23, 2016Post  #1
          The cost of construction is related to plan of the building and specification used during construction. As your inquire for rate Rs 1200-00 to 1400-00 per sqfeet include the cost of electric works.
191897
2557
2123
Cost of Construction
Last answer on 8/19/2013 11:11:40 AM. by S L Gupta (Civil Engg). Forum started by Naveed Mohamed
3542
Contruction Tool
3924
23866
1776
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
2172
2242
6040
PORTICO COST
Last answer on 6/10/2021 12:59:33 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
2705
type of brick
2664
sir i want to know that what would be the cost total consturction of 2200 sq.ft
Last answer on 2/15/2022 11:12:49 PM. by JAI PRAKASH. Forum started by shruti Adarsh
5663
What is the cost of the emulsion paint per sq ft as per today's market rate?
Last answer on 2/14/2013 11:17:01 AM. by Jemimmarichardson. Forum started by Rani
2432
16808
Construction Cost per square ft in Gurgaon
Last answer on 2/22/2013 11:53:26 AM. by S L Gupta (Civil Engg). Forum started by Pawan Rao
3196
labour cost
2223
What is acre
Swimming
Inground
Inground Swimming Pool
