Home -> Forums -> Construction -> Start Construction -> construction cost
construction cost
Tue Jan 13, 2015Total posts : 3
janak
janak
Topic: construction cost
I Want To Built Ground+3 Storey Residencial Building In Surat(Gujarat).  Plot Size Is 30'*50'. The hight of slab is 10'. Ground floor is for parking. How much Flat can built? plan is not yet ready. I want to know how much construction cost is coming including labor and material for lock and key flat for per sq ft?
Regards.
 Janak Zanzmera.
Tue Jan 13, 2015Post  #1
        You should contact any civil engineer or estimator who can calculate cost according to plan and specification.
Tue Jan 13, 2015Post  #2
VastuMoorthy
VastuMoorthy
@Janak, The construction cost will vary depending on whether you choose medium specifications or top specifications.
Medium Specs: Super concrete blocks, vitrified tiles, plywood woodwork for wardrobes, cupboards, shelves, MS grills for stairs, balconies, aashirwaad or Supreme plumbing fittings, finolex electric cables, anchor/roma switches, external elevations in cement only,  sadrahalli granite for stairs, maindoor teakwood, other doors flush doors, powder coated aluminium windows etc etc.
Top Specs: Everything mentioned in medium specs, a few things change, like, bricks, granite flooring, all teakwood doors and windows or Upvc windows, higher quality granite for stairs, like hassan green or cat's eye costing more than sadrahalli for stairs, SS grills(stainless steel) for stairs, balconies, wood windows or upvc windows, teakwood more costlier than upvc, whether you want floor to ceiling height 9 ft or 12 ft etc etc.
The quality and make of sanitary fittings also matter, like Eros or Jaguar or Hindware or Parryware etc.
Quality of kitchen sink and granite counter top also matters, plus number of 5 Amps and 15 Amps electrical points you are asking for etc.
Myself,  as a vastu consultant have attempted my best to guide you, hope it was useful.
Whatever specs you choose you can consult me for vastu compliance if you wish.
Vastumoorthy (vastumoorthy@gmail.com)
Thu Jan 15, 2015Post  #3
It will cost you around 75-80 Lac's. All inclusive in Good Material. Till Completion. Without Lift.
6088
What is construction cost
4047
4781
2337
2660
2732
1764
2535
1872
Last answer on 10/7/2020 10:22:43 PM. by S L Gupta (Civil Engg). Forum started by siva
2182
2954
2110
2164
7401
750 Sqft Construction
2419
1972
Sir I WANT TO KNOW THAT HOW MUCH CONSTRUCTION COST OF THIS HOUSE WILL BE EXCEPT
Last answer on 7/17/2013 11:42:13 AM. by S L Gupta (Civil Engg). Forum started by mahesh
4045
RCC consultant fee
Last answer on 12/4/2021 9:54:41 PM. by S L Gupta (Civil Engg). Forum started by milind jadhav
3442
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
2837
1950
cost of construction for large span of 60'
Last answer on 10/30/2014 12:27:22 PM. by Amit Hasija. Forum started by amit jain
2451
3273
3284
4429
3975
2197
2699
4210
5167
2378
2294
1996
2447
2114
3194
2046
12514
2164
2010
2726
